Midwest Extra 300xs Build
Reply
Old 05-05-2007, 07:18 PM
  #351
mrbassman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Midwest Extra 300xs Build
bar 98....I'm having the same problem, incredibly tail heavy !!! Right now I have the whole plane disassembled and giving it a good overhaul, and I'm moving everything as far forward as I can. I want to place the fuel tank right over the cg, so there's no change on balance when the fuel level changes. I had my batteries a lot closer than 8" from the ignition module and I had no problems, in fact they were about 2" apart. Right now my batteries and throttle servo are in the engine box, and the rudder servo is right behind the fuel tank. I'll let you know how I make out.
mrbassman is offline
Old 05-06-2007, 12:05 AM
  #352
KI8FR
KI8FR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was working on mine do day too.. I have the cg in the right spot but I am having glitches like crazy. I will be putting a post up to see if there are some ppl that can help me find out what is making this glitch. I know it is not the cdi that is doing it.. I can only get about 50 feet from the plane with the engine off.. whith the engine running I can get about 25 feet.. I know that is not going to work.
Keep the info comming in.
Paul
KI8FR is offline
Old 05-06-2007, 12:18 AM
  #353
RCKen
RCU Forum Manager/Admin
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
KI8FR,
How is the antenna routed out of the plane?? Do you have the antenna completely extended, or is it inside of the fuselage? Does it run next to the servos or batteries? Can you post a picture of your receiver installation and the antenna routing?
Ken
RCKen is offline
Old 05-06-2007, 01:14 AM
  #354
Cyberwolf
Cyberwolf's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the antenna is ok, I would disconnect each servo one at a time and recheck, Also your servo extensions can cause a person grief at times, Thats another thing to check. If that doesn't show up anything then I would change the receiver and try it. Glitches can be a real bear to find but we both know its better to take home a plane that glitches than one in a sack.
If you can do as Ken said and show us your set up. I had some problems also, But mine was only while running.
I had the batterys to close to each other. also the charge leads needs to be seperated for each switch, Ign& receiver.
Cyberwolf is offline
Old 05-07-2007, 03:18 PM
  #355
bar98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi mrbassman,
Could you please post the picture of your engine box, I would like to see the throttle servo installation, I have also installed the cut-off servo, ?I would like to see if I can move both to the engine box.
bar98 is offline
Old 05-07-2007, 03:38 PM
  #356
Digger44
Digger44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really need to get back to finishing mine. Still in the covering stage. I did have a pretty good reason for the detour though. Let me know how this CG issue turns out. I really want to finish this plane, Must stop buying new planes!!!![sm=thumbs_up.gif]
Digger44 is offline
Old 05-07-2007, 06:32 PM
  #357
bar98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know how Midwest got the right balance using the Moki 2.10 and just moving the battery.
bar98 is offline
Old 05-07-2007, 09:21 PM
  #358
Cyberwolf
Cyberwolf's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine come out perfect using a G-62, I lightened up alot and also use a C&H IGN. I don't know what a Mokie 210 weighs but my 62 is just a tad over 4 lbs. Its a great flying plane I might add, My problem is I don't fly it enough.
Which kits are you having the TH problem with the early or late ????
Old 05-07-2007, 10:07 PM
  #359
bar98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am having the problem with the Midwest Extra 300XS, please note that the tail on this version is heavier. I did some test tonight and I have to add around 7 oz to the nose, I will add the spinner and I will try to move the throttle servo and the choke servo to the engine box, but that is not easy.
bar98 is offline
Old 05-07-2007, 11:01 PM
  #360
KI8FR
KI8FR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is room on the out side of the box for the servos..
KI8FR is offline
Old 05-08-2007, 12:31 AM
  #361
Cyberwolf
Cyberwolf's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With my stand offs I could put the servo on the engine box is I so wanted theres enough room ,might be a way to solve some of your problem W/O adding unwanted lead
Old 05-09-2007, 09:42 PM
  #362
bar98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have installed 2.5" stand offs, and the spinner is very close to the cowl, what I will do is to use 3" stand off. Any one know where I can buy it?
bar98 is offline
Old 05-10-2007, 03:59 AM
  #363
Digger44
Digger44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[link=http://www.swbmfg.com/]SWB[/link] has them in incremental sizes.
Digger44 is offline
Old 06-07-2007, 09:16 PM
  #364
bar98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally I got the right C.G with the DA-50, I added in total 8 flat washers to the standoffs which makes now a better separation between the cowl and the spinner plate and also I added a 3.5" spinner from Dave Brown.
bar98 is offline
Old 06-07-2007, 11:10 PM
  #365
Cyberwolf
Cyberwolf's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to hear you got things going your way, I flew mine weekend before last its a nice plane with no bad habits of any kind so far.
Old 10-07-2007, 03:03 AM
  #366
KI8FR
KI8FR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My midwest extra was killed. [:@] I will rebilled her I have the wood I have the tecnolagey. but I do not have a set of PLANS. lol
I e-mailed midwest to see if I can get me a set but nothing back.
Got any ideas on how I can get me a set.
I loved that plane.
Paul
KI8FR is offline
Old 10-08-2007, 05:14 AM
  #367
Cyberwolf
Cyberwolf's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Myself I would call MW with a request for the plans. Or check to see if there website has a parts list for the plane ,if so the plans should be listed.
Old 10-11-2007, 05:01 PM
  #368
zalitarique
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
digger44 i have the same plane you are putting together. i lost the book and i dont know what the throws are on all the surfaces, is it possibile for you to print out what the throws are for aileron, elevator, an rudder. also the cg standard and dual rates or 3d. i really apreciate your time if you could possibly do that for me and good luck building your new toy. thank you.
zalitarique is offline
Old 11-11-2007, 06:04 PM
  #369
skypilot3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i brought a 300xs35% and mid west is shut down right now i dont think that thy make that big of a plane can you check around thanks alot
skypilot3 is offline
Old 11-11-2007, 07:09 PM
  #370
Digger44
Digger44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: zalitarique
If you still need this I can scan it or something. Sorry I didn't see this sooner.
Digger44 is offline
Old 11-11-2007, 08:22 PM
  #371
zalitarique
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello. I got a hold of Midwest and they send me the book for it.
I thank you for your concern.
Old 11-12-2007, 12:48 AM
  #372
KI8FR
KI8FR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What about a set of plans? lol Mine crashed and I have to rebilled it
KI8FR is offline
Old 05-10-2008, 09:36 AM
  #373
bar98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I added more modifications to the fuel tank place and servo throttle position.
It flyes really nice, easy on landing.
ID:	946639   Click image for larger version
ID:	946640   Click image for larger version
ID:	946641   Click image for larger version
bar98 is offline
Old 05-11-2008, 05:36 AM
  #374
Cyberwolf
Cyberwolf's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice mod on the tank bar98, what size is the tank? I have thought of doing the same thing with mine but I would like to add both fuel and smoke on the CG ,and i'm concerned about enough room. Another thing that has stopped me is the fact the plane flies so dang good with the tank in the original position I hate to mess with it. One of them if its not broke don't fix it deals *LOL*
Digger how is your project coming along ,its been a while since you last posted any progress.
Old 05-14-2008, 05:57 PM
  #375
Digger44
Digger44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, not a lot of progress. Still in the bones ready to cover. I'll get to it one of these days I'm sure. It's kind of on the back burner for now. I have a 35% Carden now that I am working on hopefully to maiden in a few weeks if time permits. I really do need to finish the Midwest though.
Bob
Digger44 is offline
Reply
Display Modes
