2nd Newbie Build- GP Super Skybolt
#801
RE: 2nd Newbie Build- GP Super Skybolt
Well after spending many hours reading thru all of the skybolt posts I have been inspired and starting working on my kit some more. It has been in work so about a year and I have done more in the last two days then I have in 6 months.
I have one issue that I can not get past and I am about to the stage of needing to order parts.
I am going to put a large two stroke in this plane, I was going to put a magnum .91 in it (I already mounted the motor mount for it but it will more than likely be a Evolution 1.00, I have a .46 in a kit built Bridi Kaos and I like the look and I like the price.
The question that I have is
I want to put a Pitt’s style muffler in it but I want it to fit inside the cowl. After reading about MODs... cowl issues I don't want to get that creative. I already have the fiberglass cowl and really did not want to cut it up.
Are there are two stroke skybolt flyers whose muffler fits in the cowl?
Is it the Slimline? Because the Bison that MODS used did not fit like I thought it would and I was just about to order that one
Those that have on that fit, did you mount the motor inverted or is it on its side?
Thanks for the input.
I am also going to post this is the kit building section
#802
CA
ORIGINAL: Kirt
You're right about having space issues with a Bisson type muffler. The thinnest Slimline may fit but it would be close. Might want to try [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXR599&P=0]Muffler A[/link] or [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKHU8&P=0]Muffler B[/link] from Towerhobbies. I looked through my manual and noticed the author used the same type for installing a 2 stroke. I don't see an exhaust nipple on either of these so I'm not sure how to get the back pressure back to the fuel tank [sm=confused.gif].
Can't wait to see pictures.............
ORIGINAL: bldrums
everyone has gone ...............................but guys,,,,,Im still here.....help HELLLP ,,, dont leave me now Im almost finished!!! ............guys?,,,,,,,,,hello................... .
Mods
#803
Hi Kirt,
I have a GMS .76 in my Skybolt. I mounted it on it's side and used a J'Tec JT-W120P pitts muffler. This muffler is rather BIG I think, when compared to the Bisson or Slimline pitts styles. Even though I did have to cut away a lot of the underside of the cowl, I think it still looks good in there. I've included some pics below.
Hope this helps. Good luck with the remainder of your build.
#804
MS
hey guys, sorry i've been away so long. been building a new computer you guys know how it is with a new toy.....LOL
i would also have to say some type of "in-cowl" muffler would be in order. however i don't recall seeing one for a 1.00 size 2s class engine.
somethine else to consider might be a 90 degree adapter, using this you might be able to rotate the muffler to fit behind the engine. this might force you to invert the engine from what you've got now, but it would give more distance between the muffler and the cowl. you might be albe to get away with nothing more than 2 small holes for the exhaust tips.
i haven't experimented with this just something from the top of my head, and something else to consider. keep us informed of how it turns out - whatever you decide to do.
#805
Im looking for a recommendation for a remote glow ignitor. This will be for a Saito 1.25 inverted on my SB
Thanks!
BL
....................................>>>>>>>>>>>>>> >>>>gearUP!>>>>>>>>>>>>>>>>>>>>>>>>>>
PS: I did try a search but no luck
Thanks!
BL
#806
is there anyone know? which trainer is it???
i just bought it(second hand)
i don't know the type or brand for this trainer...
thnxthnx
please send me at [email protected]/yahoo.com
thnks...
thnxthnx
thnks...
#807
Hi,
Tower Hobbies sells a couple different kinds. One is made by Dubro [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD694&P=7]HERE[/link] which I have used before and it works well. The remote head part has a sliding cover which keeps dirt and stuff from getting all over the plug which is nice. The cover/holder is a bit large however, but still makes for a clean looking installation.
The other one I have, but have not used is [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBC35&P=ML]THIS ONE[/link] made by Model Products. It has a basic angle bracket that holds the remote plug and you can mount it to the firewall or such. Then you would drill an access hole through the cowl to get your ignitor on it.
Hope this helps.
Hope this helps.
#808
I shot the cowl with several coats of Lustercote Missle Red but the finish is not as glossy as the Monocote. Is there a clear glossy finish compatable with the Lustercote paint. Hopefully something I can pick up at a local hdware dept.
thanks,Bill
.....................................gearUP>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
thanks,Bill
#809
Another question to the Skybolt builders. ( Seems I will never get enough time in to finish this thing)
Anyway, I installed the elevator control rod system per plans. I never thought this "Y" type was great but since the plans called it , I went with it. I am not happy with the amount of drag this configuration is putting on the servo. The "Y" does just what I expected it might do, since it cannot follow a straight path at the exit slot. It tends to open and close like sissors causing a bind. Did you guys have any luck with this set up? My past experience has been using 2 servos with a "spitter" for the elevator halves but, being tail heavy I went with the plans. Of course , now , to make the change , Im probably adding another month to my building process. Any short cut out of this one would be appreciated.
Thanks guys
Bill.....................................>>>>>>>>> gearUP>>>>>>>>>>>>>>>>weeeeeeeeee
BL
Thanks guys
BL
#810
IN
ORIGINAL: bldrums
Thanks guys
BL
Thanks guys
BL
The only "short cut" I can think of is to use a stronger servo. Then the load won't matter as much.
Chris
#811
Banned
Question to all the experts of the SB.
These are pictures of my wing saddle as it fit onto the bottom wing. Do I need to extent or do anything about the saddle on the fuse to either strengthen, widen or minimize the impact it may have on the wing, by either widen it where it meets the wing with epoxy and/or a piece of 1/64th ply - or is this ok?
#812
IN
ORIGINAL: bert269
But...
I use epoxy & Microballoons to make a perfect fit of the wing to the fuse. This has the added benefit of enlarging the wing saddle to spread out the load a bit more.
Iron some covering onto the wing where it will meet the fuselage (monokote, ultracote, whatever). Mix up some epoxy and Microballoons...heavy on the microballoons. Spread a thick layer onto the wing saddle. Bolt the wing on. After drying, pop the wing off and sand down the squeeze out on the outside of the fuse.
Chris
#813
Still have a few things to do yet but Im almost done. ( my "few things" always seem to go long ) Anyway , theres my progress report.
Yeah, I didnt like the kit cowl ( I didnt get a good fit between the sections ) and the MonoCote paint wasnt a close match, but if the plane flys, Ill order a fiberglass cowl.
#814
Banned
HI SkyBolters...
I need some more advise, please. Now for you that have finished building the Skybolt or anyone that might have experience with this, please help.
1) I need to make the canopy removable for easy access to the cockpit. This needs to be done quick and easy at the field. I do not want to remove screws each time I need to do that....The reason for this is, my Skybolt is going to be electric and I need to secure my battery packs from inside the cockpit as well.
What can I use for this that will give me quick and easy access? I have seen and used "quater turn fastners", but the smallest that I can get, are still too big to extend from the canopy : http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=19008183
2) Has anyone seen the "knurlned nuts" used in the Skybolt ARF to attach the struts to the wings? Where can I find these and/or directions to install them. I just cannot seemed to make the wired-method to work smoothly without damaging the wings every time I try them on. I think the nuts are a much faster and cleaner way to install the struts. Any ideas?
Bert
Bert
#815
MS
i'm sure several will chime in on the knurled nuts for the struts. i'll give my $0.02 worth on the wire struts. they worked flawlessly for me. rounded the ends of the wire nice and smooth and made sure i had ample space in the "sandwich" rib for them to slide. only problem i've got now is remembering to bring my wing bolts!!! LOL
check post #549 on page 22 of this thread ..... might give you another idea.
one problem i did run into was the wire was crushing the balsa sheeting everytime i inserted the struts....went back and found i had forgotten to "harden" the area with thin ca
#817
Hey guys,
I have searched the thread trying to find what CG measurment seems to work on the SB. At this point , mine is a bit tail heavy with the CG at the recommended 2 3/4 " ( from the le of top wing at t7) I balance out at about 3" back right now.
thanks
bill..............................>>>>>>gearU)P>>> >>>>>>>>>>>>>>>>weeee
thanks
#818
MS
at the reccomended cg and inverter the plane will nose down meaning that a bit more tail weight will re reqauired ( or it was for mine) just try the cg as per the plans (it'll fly with no worries) and adjust from there.
#820
One more satisfied flyer I started building my SB kit in August of 04. Today , I went out and maidened the aircraft. I got tired of waiting for the optimum weather ( no wind, clear ,sunny) and dropped my standards for the " perfect maiden day"..... and went for it today. Little cross wind, mugggy and humid with overcast skys. Ok, good enough, lets get it done.
With a Saito 1.25 APC 16x6 she tracked down the runway and slid effortlessly into a climb , flew like it was on rails and make several of the sweetest scale like landings you could ask for. She looked and sounded awesume up there. I flew 3 times , packed up ,went home so relieved to: # 1 : have this project completed . And # 2 : to take a completely great flying, uncrashed airplane back home with me.
Ill never be able to squeeze out nearly enough time to bulid another kit , especially one like this, but Im really proud to have this one in the air!!
Thanks to all you guys for your help and support... I wanted to quit lots of times but of course , that just doesnt happen in this hobby does it! But now I can put this one aside, done! FINISHED!.....but... emmmmm....some smoke would be nice now. wouldnt it................hehe
Good Flyin Weather to you All
BLdrums
BLdrums
#821
Congrats on the successful maiden! There's something to be said about building this bird from the pile of sticks and ply and then seeing it take flight for the first time...
#822
Thanks WYDAH, you are right about that! And it looks like we're gonna be blessed with another beautiful flying day again today!! Hope you have the same.
...............>>>>>>>gearUP>>>>>>>>[8D]
#823
ORIGINAL: WYDAH
Congrats!
#824
Hey Minn!
Yeah, two days flying and alls well................. Im thinking about retireing the plane now !!! naaa, gonna fly it like I stole it!
Oh and by the way, ( youve experienced this ) I received some very nice comments and compliments on the SB from fellow club members, and these were guys that know their stuff. I puffed up like a cheap umbrella
#825
CA
Hi club Skybolt........wish I had a computer while I was building mine. Took a year to build. So here it is..about 14 flights so far.
It flies great. O.S. 120 surpassIII w/pump. 14x10 prop. Smoke. 5" wheels (No wheel leiderhosen). weghs about 11 lbs.
14 oz. fuel tank. 8 oz. smoke tank. Smokes like crazy!!! 2-6v 1650 batts for radio and smoke pump.
No hatches[]. Covered in monocote. Cowl and struts painted with primer/lustercote/ finishing epoxy over top to fuelproof paint.
Favorite plane of my eight that can fly. woops meant seven, one is stuck over 100 feet up in a cyprus tree at the neighbors!!
Murphy
P.S. This was the first kit I ever started, But finished it third. After starting and finishing a pitts and a tiger moth.
Murphy
