servo install in wing
Reply
Old 01-20-2002, 03:02 AM
newbieguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo install in wing
i am trying to install a servo in my Tower Trainer wing. the servo will fit except for the wire that comes out of it. how do i install the servo so the wire has enough clearence?
newbieguy is offline
Old 01-20-2002, 03:38 AM
upnflyin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I am reading your post right your problem is fitting the servo into the hole originally disigned for the servo and not a modification right?
All you need to do is enlarge the hole slightly as needed to make it fit. They are designed to fit the average servo and yours might be slightly different. No problem.
upnflyin is offline
Old 01-21-2002, 12:02 AM
mselby
mselby's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
file a small groove in the side of the mount to allow the wire to clear through. Do not make the groove any wider than necessary to avoid problems with the mount holes.
Mike
mselby is offline
