glow starter....what's the best method.
#51
TX
RE: glow starter....what's the best method.
Well, not really contributing a discussion point but I use
Glow Igniter with a few old p1700 nicads in my pocket
Elect Starter on a 8cell cp1300 pack
Fires up a GP42, AP15, and Magnum52 4stroke just fine, and I can lug both and a quart of nitro & syringe in camo cargo pockets and go hours with the .15 at the flying place I had to hike to. When street flying, I alway keep a panel & cut 14ga extension cord in the car as backup
#52
Re: " Setting the output to the same place on the meter will not result in an optimal glow for each plug." < I haven't noticed it to be a concern for me. I have taken out the plugs and checked the glow vs. the setting just to see how it looks a couple of times and the glow has looked good to me so I don't bother to check it any more. Re: "IMHO if you can't hand start your engine then you are not doing something right. "< if you have an electric fuel pump then you have a good 12 volt so why not run a starter off it?? Re: " I avoid using an electric starter is that it tears up my plastic spinners."< this probably just means that you are not getting a good, quick, solid connection onto the spinner on the engine. If the starter cone is getting old or brittle or has burn marks on it caused by a less than solid connection then that could be a problem. Old cones can lose their ability to grip the spinner abd will just cause friction and heat. I had to replace a couple of starter cones before I learned how to get a quick solid connection onto the spinner on the plane engine. My last new cone has lasted 3 years and is still in good shape.
#53
My Feedback: (12)
SC
ORIGINAL: Fastsky
PS. Your style of quoting is extremely inconvenient to read. It would help if you would at least separate them into individual paragraphs instead of one run-on block of words.
#54
I use a starter and it does leave an unsightly ring around the spinner. I can see people deciding not to use one because of this. I guess this doesn't matter too much to me with my sport airplanes.
#55
NJ
I agree , although I don't use a starter much, never mind not even using a cone every now and then, the marks on the cone can't be seen when the plane is 300 feet in the air, moving at 50-140 MPH, and the cone spinning at 14000 RPM's, so I can get over the marks.
