ANOTHER BTE VENTURE BUILD
NY
RE: ANOTHER BTE VENTURE BUILD
I sandwiched the ribs between two pieces of pine and drilled all of them together, I did this before I removed the pins that hold them all together. If you have altready taken them apart you can sharpen a short piece of copper tubbing and us that to hand drill the holes. Hope this helps!!
NY
Many people on here have built this plane and if you type "Venture 60" into the search it will bring up several threads and tons of ideas. Good luck!
