Sorting out my shop
Sorting out my shop
Here is what I have got to store and work on my birds. From the boiler through to the clock. The 'slope' on the right is where the staircase is so you can see how deep the 'bench area' is. The TM400 is hung on the wall to the left of the boiler and is the only one to be 'organised' LOL but that's not ideal either. I want to be able to keep the birds as ready to fly as possible, have space to store bits and pieces, charge my packs and work on the planes. With that in mind, what would you guys do with the space ? Any pics of your own shops could be helpful.
RE: Sorting out my shop
To start with, you can hand the planes from the tail along the wall. In you case, you'll to devise a way to suspend some wood down from the rafters to there will be a place to put hooks in. Look closely at the pictures and you'll see how I use a simple screw-in hook along with some string around the tail. If you alternate one plane nose up, the next nose down you can overlap wings and really pack them into a smaller area. You can also use the same basic principle to hang them from the rafters, in a level (flight) attitude. You can also make some small shelves about 6" deep and hang them from the stairwell high enough to alow use of the bench.
You can also send me the planes and radio's you don't have room for - I'll be glad to store and fly them (to make sure they reamain in good working order, of course).
Hogflyer
Hogflyer
AK
I would start by throwing away everything that you are never going to use again. Then, throw away all of the parts that you might get around to fixing "someday". Then some hooks, plastic bins from WallyWorld, and a decent toolbox and you should be set.
MS
or if you don't want to hang 'em by the tail, hang 'em by the landing gear, i hang all my "ready to fly planes" from the ceiling just to keep 'em out of the way. i generally use two peices of small rope, one around the prop nut and one around the fuse back around the horizontal stabilizer. if you want you can take pipe insulation and run the rope through that to pad the rope against the monokote but i've never had a problem with the rope against the monokote.
hope this helps
hope this helps
My work shop is also in the cement basement. I took 8 foot 2x4's and mounted them horizontally to the wall using tap-con screws and gorilla glue. Then made 4 spaces for hanging my fuselages by their tail. I drilled 1" holes about 6" apart 3/4 way through the 2x4's for dowel rods. I covered the dowels with pipe insulation to protect the stabilizers. The fuselage fits between the dowels and holds the models great. In my small shop I have room for 12 planes hanging on the three walls I'm not using for a wing rack and storage shelves. The wing rack is about the same except I used 1x3's 7' long and screwed them to the shelves vertically about 3' apart. In your case you could use tap-cons and glue again. I drilled 3/4' holes in the 1x3's about 10" below the other on each vertical 1x3. I inserted the dowels and covered them with flexible clear tubing to protect the wings. This holds 8 wings including the first holes and dowels that are at the very top of the 1x3's. I also stapled a king sized sheet on the top of the 1x3's so I can flip it over the wings and protect them from dust when I'm building.
Gibbs
Gibbs
My Feedback: (13)
your space is screaming hangar rash for sure what I did was use adjustable shelf standards the ones with lots of adjustment slots screw them to the wall you will need concrete screws ( there called Tap-Cons in the U.S.) take the shelf brackets and like NCIS said and slide foam rubber pipe insulation over the ends, here in the U.S. its cheap and you use it for 3/4 copper pipe, it works great for padding the brackets then you can "shelf " your planes and when you need to adjust for different planes its easy move it up or down as needed here is some pics of my set up one over my building surface and one by the T.V. laundry folding table. my old building surface
MB, CANADA
I have a 19 foot by 12 foot workshop and a 28 foot by 18 foot rec room and still can't figure out what to do with everything; the point being the more space you have the more you will fill. I feel sorry for my wife who is a clean freak.
ORIGINAL: scratchonly
My Feedback: (7)
KS
What Bruce said....oh, and get rid of the beer cans and cigarette butts before company comes over and gets a different impression. Hell, that's what I did and works/(ed) out fine.
Thanks for the advice guys. I'd not thought of the 'wing rack' but it seems fairly common.
Bet you didn't notice the beer can in my photos
ORIGINAL: muzzlemaggot
ORIGINAL: netdudeuk
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: bruce88123
You call that stuff you people drink over there beer? [:'(]
ORIGINAL: netdudeuk
[X(][X(]
What kind of beer is that, I drink many different brands of imported beer from the can and bottle. Never seen that kind before. Weird can!
Gibbs
Gibbs
K1664, IMHO tastes like something a rat has passed, it is also a larger which is the same as american beer, not if you want to hurt these guys give them a good old pint (imperial of course) of old speaklehen or something like that, although I have never been a ale drinker.
J
J
My Feedback: (9)
ORIGINAL: netdudeuk
[link]http://www.k1664.co.uk[/link]
Maybe a little too hard for you American gentlemen
Now now, we won't go there!!!!!
Because we all know why the British drink warm beer!!!! Because Lucas makes refridgerators too!!!!
Having owned at least 12 british cars throughout the years I'm entitled to make this joke!!!
Ken
ORIGINAL: JPGale
J
J
ORIGINAL: RCKen
Ken
ORIGINAL: netdudeuk
Ken
If you want to talk about beer you will need to put up a few Aussie beers, there's nothing like a ice cold `XXXX' or Crown Larger after a hot day at the field, also about twice the alcohol content of US beer & about 10 times better than that warm ‘stuff’ that the pommies call beer
My Feedback: (9)
ORIGINAL: netdudeuk
You bought a British car ? Serves you right The best cars that I have bought have all been German ones
ORIGINAL: RCKen
Ken
ORIGINAL: netdudeuk
Ken
Yeah, you have to own several British cars at one time, that way you might have ONE that will start in the morning when you have to go to work!!!!
I've always had a weakness for the British sports cars, or maybe that would be better described as a sickness???
I've had TR-7, TR-7 convertible, TR-8, TR-6, TR-3, Austin Healey bugeyed spite, MG Midget, MGB, MGA, just to name some of them. I'm pretty much over that phase now. I'd rather spend the money on this hobby!!!!
Ken
ORIGINAL: RCKen
Ken
ORIGINAL: netdudeuk
ORIGINAL: RCKen
Ken
ORIGINAL: netdudeuk
Ken
Ken
