In the market for a Dremel?
My Feedback: (16)
I've noticed that Lowes has a special value price on the Dremel 2850-02. Just under $30 in my area. If you're in the market, this is a pretty good price.
RCU Forum Manager/Admin
My Feedback: (9)
RE: In the market for a Dremel?
Weasel Keeper,
Not to lessen what you are trying to say, but my advice would be to spend the extra money and get a Dremel with variable speed control. The model you pointed out is only a two speed model. I've found that being able to adjust the speed makes all the difference in the world when working with a Dremel. Using a two speed Dremel users may find that they can't slow it down enough to work well in balsa wood.
Ken
Ken
My Feedback: (16)
Ken,
I just picked one up to replace my 285 type 1 (can't get parts for it). Very cheap replacement. I find the 285 works pretty well with the 2 speeds available. I also like to have a couple of roto tools handy for various jigged operations so I don't have to re-adjust so often.
This option might mean the difference between having a Dremel or not having one for a Noob or adding to an existing arsenal for others.
PS.
You're right though. Variable speed is nice to have.
PS.
KS
Ive had my dremel 10 plus years and before i got my variable speed had a two speed and the variable when using certian bits is far superior to the two speed when working in different materials,diffrent bits different speeds,different materials require different bits and speeds. i have router attachment and a flex shaft and the dremel is a good tool for any hobby and pays for its self many times over.
My Feedback: (9)
ORIGINAL: Weasel Keeper
.....This option might mean the difference between having a Dremel or not having one for a Noob or adding to an existing arsenal for others....
In my honest opinion I feel that you can't have too many rotary tools. I have 5 of them!!! I keep several set up for different things. One I have set up with the router attachment, and another on the router table, and a last per-set one has a wood cutting blade on it. The other two I keep with a quick set chuck so I can change the tools quickly. One of the ones I use the quick chuck on is the Dremel 10.8 volt Lithium Ion cordless tool. If people can afford this model I highly recommend it. The battery gives the tool enough "ommph" to get through tough jobs, plus it gives it great run times. I usually only charge the tool once a month or so. The last tool I have quick chucked is a regular old corded tool, but it gets tons of use too!!!
Ken
My Feedback: (16)
Ken,
Have you tried the Dremel Stylus yet? I saw one in action at a traveling demo at HD the other day. It seemed quite powerful for a cordless.
My Feedback: (9)
Ken,
Ken,
Ken
My Feedback: (16)
That kinda tics me off too. My oldest Dremel claims to be part of the Emerson Corportation. I think now they are under the guidance of Bosch. Maybe it has something to do with managment changes. Of course, if the tool lasts too long, you have to come up with a marketing scheme to sell more product.
I also have a B&D RTX (variable speed). That's a nice tool, but not many attachments that fit without modification.
And you can find bargains on EBAY for Dremel tools. I picked up a scroll saw there for $10 + ship a couple of years ago and it's still going fine. Here's one 230061377052 that's only a buck so far. Condition unknown but there are bargains to be had if you are careful.
Get the variable speed dremel and you will be surprised at how well you can do accurate cutouts. I usually have mine set at the slowest speed so as to be accurate. I only use high speed to get close and for grinding or using a cutting wheel. Spend a little more, you will be much happier.
Gibbs
Gibbs
It will not work with Dremel bolt-on accessories (router, drill press, etc); but all of the bits fit it, and it does what I need at this time.
I got the Dremel multipro model 770..2 speed rechargable...the battery sucks in mine, it runs for maybe 15 minutes and then needs about 10 hours of charging if I charge it and it sits for a few days its dead again......always been like that...next one I get will have a cord!!...Rog
I have an ancient single-speed Dremel, but bought a speed control for about $10 from Harbor Freight which has made it (and other tools) into variable speed tools. When I first got it, I worried that I might burn up "old faithful" but so far (3 years) it soldiers on. Good luck, Dzl
MB, CANADA
I wired in a light dimmer switch to my first dremel. Worked fine for many years. The sdimmer was outside the tool, taped to the cord.
