Reload this Page >
Sullivan Power Pac Battery Case/Charger
Reply
Old 12-25-2006, 09:51 PM
garywi
garywi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sullivan Power Pac Battery Case/Charger
Hi,
What do you all think of this? The hobbico version cannot start a OS 91, with it's small battery. I want this to start my YS 1.10. Are they a good piece?
I don't want to do as the other guys do at the field. Use radiator clamps to hold starter to the massive 7amp battery.
garywi is offline
Old 12-25-2006, 10:43 PM
agexpert
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sullivan Power Pac Battery Case/Charger
Get a Heli-Max with onboard batteries. Mine will turn a DA 50 with no problem. It's geared, with 2 motors and 2 batteries. I think the starter itself is only $39.95 and then the cost of 2 batteries.
Go to http://www.temeculavalleyhobbies.com it's where I got mine.
agexpert is offline
Old 12-25-2006, 11:08 PM
garywi
garywi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I looked at the heli-maxx starter, and love that all in one design, but it's only rated to .90 engines. I am building my next plant with a 1.10.
garywi is offline
Old 12-25-2006, 11:38 PM
agexpert
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: agexpert
Read the part about a DA 50. Do you know what a DA 50 is?? It turns mine with NO PROBLEM!! (Although I don't actually start it that way...just a test I did with it).
Edit: That was not meant to be as rude as it sounds. A DA 50 is a 50cc Gasoline engine which turns a 22-24 inch prop.
agexpert is offline
Old 12-26-2006, 11:25 AM
staggerwing
staggerwing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been using my Sullivan Dynatron with the Sullivan battery pack for years. It works great. Put large capacity NICads in it. In the summer I can go a month between charges using it every Saturday and Sunday to start my larger 4 strokes pulus a dozen or so starts of the club trainer each day. Mine will start my Brisson 4.8 twin with no problems.
Rich
Wyoming Wind Festival Jan 1 to Dec 31
staggerwing is offline
Old 12-26-2006, 03:16 PM
KW_Counter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gary,
I've got the Sullivan starter and battery pack.
I LOVE them. I fly 40 size but have seen it used on much larger.
In fact, mine has been used by others on larger engines.
I agree with you, strapping a battery to the starter looks bulky and hard to hold.
Good Luck,
KW_Counter
KW_Counter is offline
Old 01-07-2007, 10:24 PM
garywi
garywi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, I am looking at the Sullivan starters. The specs for the yellow high torque one, says starts up to .60 engines and some up to 1.20. Well what is it? I have a YS 1.10 and I want to buy their power pac battery holder.
garywi is offline
Old 01-07-2007, 11:54 PM
garywi
garywi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The power pac takes 12 sub c Nicads.
garywi is offline
Old 08-07-2007, 12:07 PM
butchn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Had problems when using on my Saito 150's - added a 5 cell sc flat pack (salvaged out of discarded drill pack from local hardware store tool department) and strapped to side of the starter and hooked up batteries in series - now at 20+volts - no problems turning over the 150's now. Additional voltage should not be a problem since turn-on time is typically short.
butchn is offline
