Flaperons? Those keep your wings from getting tired, right?
ND
RE: Flaperons? Those keep your wings from getting tired, right?
I'm not sure how I did either.
I just ran the calculations again and came up with 23.
I must have hit a wrong button.
WA
I'm a bit confused I guess. You want the plane to fly slow on landing but as fast as possible in the air.
I assume you are not running a constant speed prop and that means that it either flies fast at all throttle positions or it flies slow at all throttle positions, relatively that is. to slow the plane down use a larger diameter prop with less pitch. if you want it to go fast then increase pitch, but it will fly faster at all throttle settings. It will even taxi faster
ND
superflea, I know. That's my problem. I want the plane to fly as fast as she can, but was hoping to use flaperons to increase the lift and thus allow a reduction of speed. I guess a solution would be to put a variable pitch prop.
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: ger87410
Ken
SC
My plane is down at the moment, so I haven't gotta chance to try this:
A guy at the field recommended I introduce elevator on touchdown to slow the plane. For example; a tail dragger like the P51 you touchdown and as the plane slows you give more and more up elevator loading the tailwheel and slowing the plane. Obvously you'll have to regulate the elevator or else you'll pop back into the air and stall. A plane with a nose gear would require opposite elevator.
It's supposed to reduce your rolling distance dramatically and keep your plane out of the weeds
Hope it helps
Hope it helps
#31
Yes, Ideally with a tail-dragger all 3 wheels should touch down at the same time. And to do this, you feed in Up elevator just before you touch down
But if the plane is nose-heavy, you'll never get the tail to "sit" before touchdown. If you're nose-heavy, when you add Up elevator, the plane will go back up rather than have the tail come down.
#32
ND
RCKen: still a bit off. Your post isn't worth a reply beyond this sentence...
I used to try to use the tail wheel to try to slow the plane until I accidentally popped the plane up cuz my speed was too high.
Take EVERYTHING with a grain of salt.
#33
the only way to solve this is for you to add the flaperons and prove that they are the greatest thing since ice cream. please post landing video afterwards
#34
ND
Everyone seems to be missing that the solution to the problem has already been found and flaperons was not it.
I don't have a good video recorder anyways.
P.S. the plane weights an amazing 5.7 pounds even with the camera.
#35
ND
I didn't notice that the solution got removed for replacing the word 'wimp'. I wasn't aware that was sometimes frowned on...
Anyways the solution was to primarily decrease the idle and secondly to decrease the height on the turn to final.
#36
PA
ger87410
yeah its funny, It was like alot of people said...... technique. and by the way. I'm sure that RC Ken has forgotten more about rc planes then most of us will ever know.
