Battery Chargers
Banned
Battery Chargers
As long as you get the polarity right... the glow ignitor charger will be fine. 1300 mah C/sub-C cells are the most common batteries in the little glow ignitors.
You can have the charger still do glow ignitors too... put on a 2 wire tyep mini phono plug. Phono plug jack in the plane for charging the o-board. A wheel collar with flats filed on to form a hex outer shape adapts a phono plug to a Ni-Starter. (some of the glow chargers... no mods... loosen a set screw and the hex comes off.)
sullivan makes a remote
its shaped like a glowplug and wires to the two wires you refered to. put it where ya want, and use a standard glow lite charger. costs about 4.00. Then your worries of fryin sumthin will be put to rest.
david
david
