Can too high a tank cause deadsticks?
RE: Can too high a tank cause deadsticks?
Kind of interesting from Morgan fuel.Of course to a minute degree they have a point but after all they want to sell fuel so guess we shoild just throw away what is left after flying??? Not at the cost of fuel will I do that. Anyhow this thread has all the answers you should need. Interesting that you seemed to have solved your problem by removing muffler baffle. Perhaps the small vent in muffler had been clogged with whatever and in the process you got it cleared. Anyhow this hobby has many many little annoyances but they usually have a solution. All part of the learning process. Keep them flying.
My Feedback: (18)
OK
ORIGINAL: cappaj1
So my routine from now on is going to be to just fly the last flight of the day as close to empty as possible and leave any remaining fuel in the tank, then to remove the lines from the carb and muffler, run any remaining fuel out of the engine, and lastly to add after run oil through the carb hole and turn over the engine by hand to lubricate the engine thoroughly.
