What is a "crutch"?
Reply
Old 10-31-2008, 05:23 PM
H5487
H5487's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What is a "crutch"?
Every once in awhile, I run across a reference to a "crutch", usually in reference to building a fuselage.
What's a "crutch"?
H5487 is offline
Old 10-31-2008, 05:32 PM
DavidAgar
DavidAgar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: What is a "crutch"?
A crutch is typically some wood put together to support the fuselage to make sure that it is built straight. You will also see them in kits for getting the wing dihedral correct or for getting the wing washout built into the wing. Good Luck, Dave
DavidAgar is offline
Old 10-31-2008, 06:33 PM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The crutch was once a popular means of building a fuselage and was used for freeflight and control-line models. It made it simple to build a non-square fuselage cross-section. This is a kind of keel which looks just like a medical crutch placed flat on the table. Formers were than added to it and the crutch was removed from the building board so that additional formers could be added to the other side. It helped to make for a straight structure.
The photo shows a modern example in Tom Hunt's Miss Stik Senior. The widest part of the framework is the crutch.
Dsegal is offline
Old 10-31-2008, 07:10 PM
H5487
H5487's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Guys!
H5487 is offline
Old 11-01-2008, 08:57 AM
Missileman
Missileman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To simplify, it is any temporary support used during construction.
Missileman is offline
Old 11-01-2008, 06:09 PM
H5487
H5487's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmmm, now I'm confused. Two people said that a crutch is a temporary support (not part of the finished model) whereas one said that a crutch is an integral part of the finished model?
H5487 is offline
Old 11-01-2008, 07:23 PM
j.duncker
Moderator
j.duncker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Definitely an integral part of the fuselage in every one I have built.
j.duncker is offline
Old 11-01-2008, 09:44 PM
hogflyer
hogflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A crutch is an integral part of the structure and used to give a very accurate fuselage. Once the crutch is pinned down on the plane, the bulkheads for either the upper or lower fuselage are glued in place and the remaining structure for that half is added. Then the fuselage half is lifted off the plans and the other half is built on top of this to crate a straight fuselage.
Crutches where very popular on free flight models and early RC models but have since died out for the most part.
Hogflyer
hogflyer is offline
Old 11-01-2008, 10:08 PM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
> To simplify, it is any temporary support used during construction. <
Nope, it is a permanent part of the structure. It is not a jig.
Dsegal is offline
Old 11-02-2008, 07:16 AM
Villa
Villa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New fliers have a hard time learning how to level the wings when the plane if coming toward them, because the required input seems to be backward. Ever hear of the verbal crutch "go for the low wing"?
Villa is offline
Old 11-02-2008, 07:57 AM
Missileman
Missileman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dsegal
I still dissagree. A Crutch can be left in or removed but is still a temporary support until the structure is completed. A crutch does not serve an integral support on the finished model. I guess some terms differ from place to place and personal experiences.
We can agree that a crutch holds key parts in place for proper alignment.
Old 11-02-2008, 09:25 AM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Missleman, I have been building model airplanes for more than 65 years. I don't recall seeing crutch used in the model building literature as other than an intergal part of the fuselage. As a general term it can be applied to a temporary support, but it has a widely accepted specific use in model airplane construction.
Jim Thomerson is offline
Old 11-02-2008, 03:28 PM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've also built hundreds of models that used a crutch, some verical (build left half of fuse then remove crutch from flat table and add the right half) on also horizontal crutches where the top half of the fuse was built on the crutch and then the assembly removed from the table and the lower half of the fuse built on the crutch. Joe Ott models almost always used a crutch as did most of the 5 and dime rubber jobs back in the 40's. The crutch was always part of the finished model.
Rodney is offline
Old 11-02-2008, 03:39 PM
hogflyer
hogflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Missileman
Quote:
ORIGINAL: Dsegal
Then what you are describing is a jig, not a crutch. A jig is removed from the structure when the structure is capable of standing on its own without movement, warping, etc.
Hogflyer
hogflyer is offline
Reply
Display Modes
