Reload this Page >
Stater batterys?
Stater batterys?
Old 11-10-2008, 09:25 PM
andrewtexas123
andrewtexas123's Avatar
Default Stater batterys?
http://www.horizonhobby.com/Products...?ProdID=HAN167
Do all batterys for glow starters have to be 1.3aH and what does that mean?
Thanks!
Andrew
Old 11-10-2008, 09:46 PM
8D3
Default RE: Stater batterys?
No,they dont have to be.The ah is the amount of power the battery can store.Basically the larger the amp hour rating,the longer the battery will last between charges.You can use about any 12 volt battery for your starter.The type you have pictured are common in our hobby.They are lightweight and safer than a lead acid battery(lawnmower/motorcycle type).Thats a pretty good price in the ad you have.
Old 11-10-2008, 10:15 PM
andrewtexas123
Sorry im new to glow wha kind of charger do I use with this kind of battery?
Old 11-11-2008, 12:03 AM
ChuckW
ChuckW's Avatar
Keep in mind, this is a 12V battery for running an electric starter motor that spins the engine. It isn't for heating the glow plug.
To charge it, you can use a variety of 12V chargers but a simple wall charger is usually all that's necessary. It fact, you can get a higher capacity battery and charger combo from Horizon: http://www.horizonhobby.com/Products...x?ProdID=HAN19
you can also buy an inexpensive charger separately: http://www3.towerhobbies.com/cgi-bin...?&I=LXL353&P=0
For your glow plug, you'll need something like this: http://www3.towerhobbies.com/cgi-bin...?&I=LXD699&P=0
Old 11-11-2008, 11:05 AM
bruce88123
1.3 AH is a pretty small capacity for a starter IMO. You should get the 7AH battery listed in post 4. A bit more money but worth the difference.
Old 11-11-2008, 11:19 AM
andrewtexas123
Can I use a lead sealed battery?
Andrew
Old 11-11-2008, 11:21 AM
-pkh-
-pkh-'s Avatar
The largest SLA (Sealed Lead Acid) battery I could fit in my field box was a 12Ah battery, which costs about $40 with shipping. It's heavy, but it has plenty of capacity for powering my electric starter & electric fuel pump, as well as running my field chargers to charge up my RX/TX batts and LiPo packs for my small electric planes. I've found BatteryMart.com to have a pretty good selection and prices:
[link=http://www.batterymart.com/p-12v-12ah-sealed-lead-acid-battery.html]12V 12Ah SLA Battery $40 shipped[/link]
[link=http://www.batterymart.com/p-12v-7ah-sealed-lead-acid-battery.html]12V 7Ah SLA Battery $26 shipped[/link]
[link=http://www.batterymart.com/p-12v-1a-sealed-lead-acid-battery-charger.html]12V 1A SLA Battery Charger $17[/link]
Old 11-11-2008, 01:21 PM
cruzomatic
My Feedback: (17)
Here you go. Here's my setup. Works perfect!!!
ID:	1070113   Click image for larger version
Old 11-11-2008, 01:53 PM
andrewtexas123
HAHA nice!
Next question is what power panels are you guys useing?
Andrew
Old 11-11-2008, 02:26 PM
-pkh-
-pkh-'s Avatar
I like the Hobbico Accu-Glo II:
http://www3.towerhobbies.com/cgi-bin...&I=LXFKZ1&P=ML
Old 11-11-2008, 03:02 PM
Rodney
Since you are apparently new to using this type of battery, I'll alert you to two of the most common problems that will seriously limit the lifetime of your Pb based cells; deep discharge and to high a charge rate. Lead acid batteries do not take kindly to deep discharge, as soon as your battery falls to 11.9 volts under load, recharge. Never charge a sealed lead acid battery at a higher rate than 0.1C (700 ma for a 7 amphour battery). The advice to get a larger capacity battery is a good one. While slightly heavier, most lawn mower batteries are a good choice of low cost and high capacity. They are heavier and require some maintenance such as adding distilled water occasionally and AWAYS KEEP UPRIGHT. Check out www.rcbatteryclinic.com for some good advice on the care and maintenance of all types of batteries.
Old 11-11-2008, 03:40 PM
carrellh
carrellh's Avatar
The battery you linked http://www.horizonhobby.com/Products...?ProdID=HAN167 is mostly intended to go in the Hangar 9 Starter Source, which is a battery box designed to be attached to a Hangar 9 electric starter. The charger that's intended to be used with it is http://www.horizonhobby.com/Products...?ProdID=HAN166
Battery 14.99
Charger 9.99
Total 24.98
Since you followed up with a question about power panels I now get the impression that the battery will be used for more than just a starter. If you will be running starter, fuel pump, field charger, etc off of one 12 volt battery you need to go for higher capacity.
The 7Ah batteries seem to be a decent compromise of weight and capacity. There is a Hangar 9 battery/charger combo available for $29.95
I havethe power panel -pkh- linked and like it pretty well. It has voltage indicators that tell me when the battery is getting low. Of course those lights do drain the battery if you forget to turn off the switch.
Old 11-11-2008, 03:43 PM
flyinrog
I bought a jumper battery box from Walmart for $36 , that I use for field charging and every thing else..including the guy that leaves his doors open all day and goes "uh-oh
".I also keep a small 12v 7ah battery in my box for the starter and the glow panel, ..Rog
Old 11-11-2008, 04:00 PM
bruce88123
ORIGINAL: -pkh-
One extra nice thing about this panel is that it will keep your glow plug starter charged if you forget to do it at home. Never over-charge ANY of your batteries though.
Old 11-11-2008, 04:39 PM
Alex7403
Alex7403's Avatar
ORIGINAL: andrewtexas123
HAHA nice!
Andrew
if you are using that setup battery attached to the starter, you dont really need the power panel or a traditional wooden flight box....
its just adding complexity and luggage to carry.
glow stick and not the one that attached to the panel.
Fuel pump is better when its manual.
check this one: http://www3.towerhobbies.com/cgi-bin...&I=LXL372&P=ML
Alex
Old 11-11-2008, 05:03 PM
opjose
opjose's Avatar
The Tower Hobbies Hobbico Power Core Starter Pack MkII works BEST when used with a pair of Wolfpack (or other racing ) batteries and a Heavy Duty starter...
e.g.
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXL372&P=ML]Hobbico Power Core Starter Pack MkII - Click me![/link]
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTJH4&P=ML]WolfPack Batteries - Click me![/link]
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXL398&P=ML]Hobbico TorqMaster 180 Heavy Duty - Click me![/link]
Yes the batteries FIT inside the Power Core case, and you can throw out that almost useless 12v battery they include.
Throw it all together and you'll have no problems starting engines up to 50CC in size, while not having to recharge the starter each night...
One charge may last you for a few weeks worth of starts.
Old 11-11-2008, 05:40 PM
andrewtexas123
People are mentioning charging there lipos throught the 12v battery I have a dc charger that uses the plugs that plug into the panel but what pannel will i need for that to plug into?
Thanks every one new to glow
Old 11-11-2008, 06:06 PM
-pkh-
-pkh-'s Avatar
Just use the starter jacks on the panel, or do what I did, wire up another jack on the side of your field/starter box for a separate battery connection.
The starter jack on the power panels are not fused, so for some added safety I installed a 20A fuse on the extra battery jack. Now I can hook up a charger and run it while I use the starter jack to start my nitro planes.
Old 11-11-2008, 06:10 PM
andrewtexas123
Sounds like alot of work lol Any way you could get me some pictures so I can better under stand what you did and how you wired it up!
Andrew
Old 11-11-2008, 07:27 PM
-pkh-
-pkh-'s Avatar
Andrew
Well, if you can handle wiring the power panel to the battery, I'm sure you can figure out how to wire another jack to the battery as well. Below are photos of my field box. The removable starter box on the end has the 12V 12Ah SLA battery in it. Both the power panel and the jack on the side are wired to the SLA battery inside.
ID:	1070429   Click image for larger version
ID:	1070430   Click image for larger version
