bend tubing
MA
RE: bend tubing
I use a drill bit or hex wrench. Get a size that easily slides inside the tube but is not too loose. Pull on the drill bit until the brass tube starts to bend. As you are bending press the tube against your thumb to help shape the bend and prevent the tube from breaking.
Photo 1: Start the bend slowly. Use your thumb to shape the bend.
Photo 2: The finished bend
RE: bend tubing
I have this one from Dubro and it works pretty well
http://www3.towerhobbies.com/cgi-bin...?&I=LXE228&P=7
I also have the K&S spring type and they also work well
http://www3.towerhobbies.com/cgi-bin...?&I=LXR791&P=7
Someone told me they slide weedeater string into the tube, bend, then pull out the string. I've never tried that.
RE: bend tubing
I use the Dubro bender http://www3.towerhobbies.com/cgi-bin...?&I=LXE228&P=7 Works great.
OR
RE: bend tubing
I have heard that you can also fill it with water and freeze it, then bend it with the ice inside, then let it thaw. But the sand or salt is the same principle and would probably be faster than waiting for the water to freeze.
