Too pretty to maiden?
#51
My Feedback: (18)
OK
RE: Too pretty to maiden?
I think I was holding the tach too close, if I hold it at the recommended range the rpms drop. I tuned it from there to about 9200 and when I hold the plane straight up it continues to run just fine. I loosened my grip on it a bit and it tried to take off vertically.[X(] I think its making plenty of power!
#52
MO
That is just great on the thrust! The 3 blade will make more thrust on a four stroke
most of the time, as they produce more torque. Your air speed will be on the low side
though but that may be just what you want at first. Good luck and happy landings. Tim
#53
brett65, please do not put to much stock into the numbers you get from a tach. All you can get is static RPM on the ground. When the plane is in the air and the load is reduced on the motor it will run a higher RPM. If you try to get peek on the ground you will be too lean in the air and be wondering why your plane keeps dead sticking.
#54
FL
ORIGINAL: Mr67Stang
Brett,
What 67Stang said, it's common practice.
Bob
