Flaps-possible with 1 servo on each wing?
My Feedback: (16)
I have a question that I was unsure where to post it on the forums, so I chose this one. With modern computerized radios, is it possible to have one servo on each wing operating both ailerons and flaps when called upon ? I thought it would be necessary to have dual servos on each wing, one to operate the ailerons and another to operate flaps, but now I don't know if there is another alternative. Could the ailerons serve as flaps on the landing approach? In other words, can one aileron servo on each wing also function as a flap servo (ailerons droop down) when landing and still continue to function as an aileron servo so wings could be maintained level as plane lands?
Don
Don
RCU Forum Manager/Admin
My Feedback: (9)
RE: Flaps-possible with 1 servo on each wing?
Yes, they can. This function is called "flaperons" and most computers radios will allow you to set this function up. But..... I highly recommend against using flaperons. More often than not they cause more problems than they solve. Once you drop the ailerons down in to a "flap" like position the wing will become more prone to tip stall (the wingtip stalls and quits generating lift, and drops). A tip stall on approach is a sure way to be bringing home a plane in a garbage sack.
If you want flaps on a plane then I recommend to build dedicated flaps into the plane and set them on a seperate flap channel on the radio. There is nothing wrong with having more than one servo in a wing. Heck, my Top Flite B-25 has 3 servos in each wing (1 aileron and 2 flap servos) side, for a grand total of 6 servos in the wing alone!!
Ken
Ken
The Hobbico Nexstar provides directions for true flaps with one servo. That is you have four separate control surfaces (2 inboard as flaps, 2 outboard as ailerons) just like fullscale aircraft. So you need a total of three servos for the wing. 2 for ailerons, 1 for flaps.
WOW -you guys are fast as I was typing you all posted the info already - Yup those guys are right altho I have it on 2 of my planes but mostley for flight line looks and the wow facter
My Feedback: (16)
Thanks for all the great info guys. After reading your posts, I think dedicated servo(s) for flaps is the smart way to go.
Don
Don
FL
Flaps can be setup using one servo using a torque rod setup coupled together allowing for each wing flap to operate in unison with each other. This is provided the ailerons are setup with separate servos in each wing.
