FUEL PUMP
TX
RE: FUEL PUMP
I come across quite a few and the washer fluid is flamable, so I figured I'd try it. Just finished testing my bushing to see if is was fuel proof or if the glow fuel would eat/swell it, so far so good.
dan
dan
My Feedback: (-1)
RE: FUEL PUMP
I wondered about the same thing, never gave it a try though. When I was still building sand rails we were using an electric fuel pump made by Facet. It was discovered by some of the guys burning alcohol for fuel that the pumps weren't lasting very long? Seems the alcohol would dry out the rubber or soften it and the pumps would start loosing pressure or the nylon pump ball would spin on the shaft? Anyway, I hope you try it and let us know sometime down the road how it works out for you. I use the small hand crank pumps designed for glow for my gas pumps without any problems. Nothing in them besides a plastic impeller.
TX
RE: FUEL PUMP
Well, I finally assembled it all and the windshield washer pump leaked like crazy. I will try another when I get it, but this one did not have any problem before the glow fuel. At least the seal/grommet worked.
dan
dan
My Feedback: (-1)
RE: FUEL PUMP
ORIGINAL: ChuckW
I think some washer fluid actually contains methanol so I imagine it would work for glow fuel.
TX
RE: FUEL PUMP
I know they use methane in glow fuel, and we use 60% in our washer fluid, but something in the glow fuel ate right through the washer pump. took about 4 seconds before it started leaking.
