RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Beginners (http://www.rcuniverse.com/forum/beginners-85/)
-   -   Gas RC was a mistake !!!! (http://www.rcuniverse.com/forum/beginners-85/10892991-gas-rc-mistake.html)
YearningtoFly 01-05-2012 09:58 AM
Trained on the sim extensively. Feel confident.
Started with parkflyers. No issues.
Decided to get a gas trainer, look at clubs and an instructor.
Instructor tells me...no rudder.....you wont even touch the rudder when you fly with me. Most guys and instructors dont use the rudder out here.
Want to buy a gas trainer and radio?
Park is where it is at for me.
vpresley 01-05-2012 10:04 AM
RE: Gas RC was a mistake !!!!
I think you mean GLO? Not gas. Sounds like a bad instructor, rudder is very important to learn. Glo is a little more clean up, but its also longer flight times and more power, unless your spending the big bucks for large electric motors, ESCs and LiPo batteries. Sorry to hear of your bad experience. Do whats easiest for you.
Vince
kenh3497 01-05-2012 10:09 AM
Yes, sounds like a poor instructor. Seek another club and or instructor. If you are doing OK with your park flyer you should do fine with a gas/glow trainer. An airplane is an airplane. They all use the same principle to fly. some just fly "different' than others.
I hope you find someone to help you out.
Ken
opjose 01-05-2012 10:27 AM
The normal progression is from smaller park flyers to larger glow then gas planes ( though large electrics are coming into the mix too ).
As your skills increase, though you may still find the foamies and park flyers fun at times, you'll want the better flying characteristics of the larger planes.
For the most part once you get into 1.8 meter wingspans and above, you must go gas.
The instructor was correct in trying to get you to forget about the rudder, especially if you are coming off of 3 channel park flyers.
You do not use it for NORMAL flying, and 3 channel park flyers tend to teach you to use the rudder in an inappropriate manner.
After you become proficient with aileron planes, you move back into utilizing the rudder for co-ordinate flight and counteracting winds upon landing.
If more advanced skills are not for you, that's OK too, but don't write off gas/glow planes because you may not be able to handle them ( YET ).
blikseme300 01-05-2012 10:28 AM
Quote:
ORIGINAL: YearningtoFly
Want to buy a gas trainer and radio ?
Sorry about your lousy experience. Most likely the "instructor" can't even fly using the rudder. Too often such blow-hards destroy the desires of new comers to become involved with R/C flying.
My suggestion is to find another instructor who can help you with your quest.
Bliksem
SeamusG 01-05-2012 10:32 AM
Find another instructor as his communication "style" doesn't work with you!
You instructor should be one that will help you learn how to most effectively use ALL of the available controls - at the right time. It may well be that to execute the basic maneuvers that are performed as part of your initial flight curriculum do not require the use of the rudder (yaw) control. If so - he should say that. He should be able to tell you the maneuver and the required controls, show you the maneuver using the required control and talk you thru the execution of the maneuver using the required controls.
As far as the comment that most guys out here don't use a rudder - emmm. Watch them fly. Are they flying maneuvers in a way that you want to fly? Are they flying race track patterns all day? Are they boring holes in the sky and cranking the sticks - watching to see where it ends up - many times surprised? Are they following a specific plan, performing a set of well formed patterns? Are they doing really hot 3D maneuvers? Are they gliding around the sky looking for and catching thermals? How do YOU want to fly? Did you tell the instructor where YOU want to get to?
My club has free training on Thursday afternoon/evening. The goal is to enable fliers to "solo" - that's it. Be able to take off, circle the field and land 3 times without crashing or putting someone else in harms way. Once we solo, the rest is up to us. The only time we use the rudder during initial training in preparation for soloing is ground control - turning the plane to get onto the runway and returning the plane to the pits. Is it necessary to successfully perform the maneuvers required to solo? Nope.
Our instructors can, without a doubt, help the student take it to a much higher level - once they have "soloed". If the student asks & can articulate what they want to do.
As you know - all the controls have their purpose and time to use them. Some trainers only have throttle, elevator and rudder - no ailerons - and they are flown very successfully. Can you fly without using a rudder - sure. Funny watching ground maneuvers without the rudder. Can you fly without using the ailerons - sure.
Try again with another instructor - this time sit down and tell him what you want to do and go from there.
Good luck.
Gray Beard 01-05-2012 10:38 AM
With a new student I don't teach rudder until the student gets to a certain point, Some right away and others quite a while. After a student is good at the figure 8 and circle I start talking about the rudder then have them start playing with it a little to see what it does and how much is needed. Then I will have a student add some rudder in a turn to get a feel for it. I use my own trainer and it has a rudder, I just don't let the new student use it for a while. Ailerons and elevator first. BUt no rudder at all?? I don't have a plane without a rudder. As an instructor I use my own equipment too. The one and only thing one of my students needs is there own glow fuel. I don't think a person wanting to try or just thinking about the hobby should be buying anything. I have seen people spend a bundle on equipment then discover they didn't have the time or care for it then they are stuck with things they can't get there money back from.
Maybe you should look for another instructor.
pdm52956 01-05-2012 10:48 AM
Out of curiosity, how many times have you been up up this instructor? How many channels are you flying with when you're out with your parkie?
opjose 01-05-2012 10:49 AM
Quote:
ORIGINAL: SeamusG
Newbies are normally taught to keep their hands off the rudder to get them aclimated to using the ailerons for primary control.
That is a proper teaching proceedure that this poster may have not understood.
Indeed most newbies have their hands off the rudder until they have progressed quite a bit.
Someone coming off a 3 channel park flyer may not understand that.
YearningtoFly 01-05-2012 10:55 AM
i fly a 4 channel t-28 in the park.....I purposefully stayed out of 3 channel as learned from the getgo with rudder on the sim
i tighten my turns with judicious rudder...maybe  im doing it wrong
never been up with him was directed to him from the field
in our conversation i mentioned coordinated flight, shallow bank angles and rudder usage
and that is when he advised me about not using or even touching the rudder with him
i wanted to join at this field due to the bisecting runways
but might look into the other club in tampa
jmcowart 01-05-2012 10:58 AM
Hope this is not off topic, but - Are instructors normally paid for their time and instruction? Is that something that is worked out individually with club-associated instructors? If normally paid, how much is standard or accepted? Thanks guys.
pdm52956 01-05-2012 10:59 AM
Well, you have one thing in your favor........you've been using 4 channels so at least you have a feel for it already.
Come to think of it, you have another thing in your favor.........he isn't the only instructor out there!
You know, I should clarify myself and that's why the edit. I'm making the assumption that you explained to this guy what experience you've had. It wouldn't be fair to him to take his comment about NOT using rudder and chastise him if you didn't tell him you're familiar with it. Of course not having flown with him before, he really doesn't know your abilities and he may just be overly cautious because of that.
Also if he was to start instructing you, or anyone was to start with you, would you be flying something of theirs or a clubs or would it be a plane of yours? If it's something a club or instructor has, then it might be prudent to do it their way to start with until you and him are comfortable with each other and you have a chance to show him what you're capable of.
Just my thoughts.
SeamusG 01-05-2012 11:17 AM
ILB
kenh3497 01-05-2012 11:22 AM
and that is when he advised me about not using or even touching the rudder with him <
Sounds to me like YOU should be instructing HIM. LOL :D
YearningtoFly 01-05-2012 11:25 AM
my plane, radio fuel everything
i am going to go to the field and pay someone to dial in and test fly my plane...first
then I have a few suitable flying spots over private land
MinnFlyer 01-05-2012 11:29 AM
Quote:
ORIGINAL: jmcowart
No, they are not usually paid, But if he does a good job and gets you to the point where you solo, buying him a gallon of fuel, or taking him out to dinner is not unheard of
Gray Beard 01-05-2012 11:32 AM
Quote:
ORIGINAL: jmcowart
I only know one person that charges for lessons but he doesn't get a lot of students. There are places that have professional instructors and that's all they do. These can be great places to learn if you have the time and money. You can find there advertisements in most magazines. The AMA has a program to get a certification as an instructor but I only know one person that has bothered with it.
For the most part those of us that will teach RC flight feel someone took the time to teach us and it's just a pay back to the hobby. The only thing I request is the student buys his own fuel. I don't want a student to buy anything else. We will use my equipment and plane. I have the buddy box and a trainer that is set up in my TX. After solo I let the student fly my trainer while they are getting there own plane and gear. I usually help out with that too just to get them going. I have a lot of stuff I don't use so I just give it to them if they need it.
For those wanting to learn to build there own kits I also teach building. These days that doesn't happen very often. I think I'm pretty normal as an instructor and don't do anything anyone else doesn't do. I have only lost one trainer with a student flying it after solo. No big deal. I don't buy trainers, someone at the field usually has an old one hanging on a wall they don't want and they just give them to me.
Some clubs have a person that is the club instructor and they have a club trainer on hand. I had only belonged to one club that didn't have a club trainer all set up with a buddy box.
ackroyd 01-05-2012 12:06 PM
Also sounds like a bit or old style snobbery. If you can fly a 4 channel parkzone plane, you can easily fly a 4 channel nitro trainer. The material the plane is made from is irrelivant, in fact some parkzone planes are much harder to fly than a traditioanl 40 size trainer. If you've been flying rudder then make sure he's aware and tailor you're training accordingly.
IMHO, a small mirority of the more stuck in their ways, instructors view foamies as toys and so not real RC, so you need to start from scratch. If this is your instructor, then i would suggest you find another.
lopflyers 01-05-2012 12:14 PM
I have to agree, rudder is something newbies should not bother to learn until they are profient with aileron turns. But for crying out loud, someone has to teach us how to use it before we solo.<div>Get someone who teaches you the right way.</div><div>I bought my. Instructor an engine he wanted as a gift after 6 long months of flying school.</div>
lopflyers 01-05-2012 12:32 PM
Ah, don't sell anything I know you will regret it lateri
Gray Beard 01-05-2012 12:56 PM
Quote:
ORIGINAL: lopflyers
I have to agree, rudder is something newbies should not bother to learn until they are proficient with aileron turns. But for crying out loud, someone has to teach us how to use it before we solo.<div>Get someone who teaches you the right way.</div><div>I bought my. Instructor an engine he wanted as a gift after 6 long months of flying school.</div>
Correct. When a students turns are no longer dropping and they can fly in both directions then I start to introduce rudder. I make it one of those things I tell the student to try during straight and level flight just to see what it does then introduce it into the flight. My thinking is as long as I have control of the buddy box there is nothing a student can do to crash a plane. Only thing that makes me crazy is when a student does or tries something before he tells me he is going to do it. My son just loves doing it to me but he has been into RC cars, boats and even helis for years plus he has had a sim forever. Other then landing he has been able to fly from day one. Another one of those one day solo people. Due to weather when he comes to visit I just haven't had a full day with him or he would have soloed right away. Makes me nuts, took me a month to solo flying a couple times a week. Then it took a long while to get to the point I felt like an RC pilot. I had a 12 year old solo in one day. The kid was borne with a joy stick in his hand though and never has felt the knee knocking until it was his own plane he spent his own money on. It was too much plane for him too.
opjose 01-05-2012 12:59 PM
Quote:
ORIGINAL: ackroyd
There's a world of difference between a 12oz park flyer foamie and a 9lb nitro trainer with a 1.8HP engine fitted to the front spining sharp Ginzu blades.
Some Parkzone planes teach you better than others, but saying that "if you can fly ( any ) 4 channel Parkzone plane, you can easiy fly a 4 channel nitro trainer" is poor advice.
The instructor(s) teach you things that NO Parkzone flyer will.
Rodney 01-05-2012 01:05 PM
If flying the bigger glow or gasoline powered planes, rudder is almost a necessity, especially if there is much taxi work involved (which is recommended). You are , IMHO, doing a disservice to the student if you do not clue him in on when and how to use the rudder on any four channel plane. How much usage depends on the type of plane and field conditions.
jester_s1 01-05-2012 01:20 PM
If you like the club's facility and the rates are fair, then join and enjoy it. If there's anything I've learned in this hobby it's that no one modeler represents the hobby or any club. You got off on the wrong foot with that one instructor, so choose another one. If you can't choose another one, then work with this guy and do what he tells you until he's convinced you are capable of solo'ing. Then you can fly however you want to.
rv9-a 01-05-2012 01:23 PM
Am I missing something? Most Trainers are high wing with tricycle gear and a steerable nose wheel. Most steerable nose wheels are tied to the rudder. If the student can't can't touch the rudder who steers the plane while its on the ground ?
rv9-a
