Super Tigre G 90 Muffler: Lost front baffle
I have a Super Tigre G90 ringed engine with the company supplied muffler that comes with them. The front baffle came loose. I pried it out of the muffler.
Question: Will the engine still run OK without the front baffle? There is still a second baffle behind it. |
RE: Super Tigre G 90 Muffler: Lost front baffle
It's a common problem on certain styles of that muffler. It has never changed performance on the three of them I had come loose.
david |
I've been running my STs (75 and 90) without the baffles for 5+ yrs now with no ill effects. Just fly it and enjoy it without that rattling noise.
I have a ST 40 ringed and wanted to remove the baffle if it has one. I couldn't figure out how to get the friggin' muffler apart. How do you disassemble these mufflers?
I put a punch in the exit, knock the baffle loose. Then twist it out from the header opening. Works great on the 90 size.
david |
These mufflers do not come apart. You have to remove the baffle through the exhaust inlet using a stong pair of needle nose pliers. Grab the baffle and twist it out. If the baffle is not loose, you'll have to remove the rivet holding it.
