control throws
Whats the best way to measure control throws in degrees? Just a plane old protractor or do they make something better or easier?
Thanks |
RE: control throws
RE: control throws
1 Attachment(s)
Even cheaper... I mean less cost... :D is this one:
http://www2.towerhobbies.com/cgi-bin...&I=LXK260&P=ML I just don't know if it does it in degrees or not. DS. |
RE: control throws
That one works well... but it doesn't allow for setting up higher 3d throws....
RE: control throws
Heres one that is simple and measures in degrees
http://www.centralhobbies.com/Tools/tool1.html#THROW |
RE: control throws
I use a simple tool that has been around for many years. It's called a Ruler.
RE: control throws
but then you have to use that pesky trigonometry to figure out the degrees.....[:-]
