Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
E-Starter brushless motors
Old 07-31-2003, 06:51 AM
YZ-212
Default E-Starter brushless motors
I'm replacing my motor on my gws e=starter and wast to move to brushless. Flying weight now is about 14 oz and the stock motor is the GWS EPS300C . I'm not looking for hovering performance, but would like a power increase. For power I'd like to be able to use a lipo 2s or 3s 1200 or better. I'd also like the motor to mate to a gws gearbox. Any suggestions?
Old 08-02-2003, 12:04 PM
e-bird
Yes the 300's shaft's get bent easy and the motor isn't very good
so I got 2 of the nippy400's Get a couple of xtra mount's I use them on more than one bird On a Slow Stick it will hang on the
prop if need be. Dymond have a wide selection. CU
Old 08-05-2003, 09:48 AM
slacsteve
Default AeroMicro.com
Check out the astro 010 brushless in a GWS300C at AeroMicro.com. Just the ticket.
Old 08-05-2003, 05:41 PM
cdallas
The astro's have a heat problen when
you push them just a little. They are pretty efficiant though with the little props
especialy for fast birds . CU
Old 08-09-2003, 01:02 PM
PlaneInsane
Im running a Razor RZ350 in my EPS 300C gearbox. It's the perfect replacement for the stock motor and you get a very healthy power increase and drop almost an ounce in overall weight. Course the caveat is the price at $145 with controller (Castle Creations Phoenix25). But once you make the conversion you won't be sorry. I use an O-Ring around the motor case to make it snug inside the gearbox. Works perfectly.
Old 08-09-2003, 01:30 PM
Greg Covey
Greg Covey's Avatar
Both alternatives, an Astro Flight 010 or Razor RZ-350 are elegant solutions.
I haven't tested my Razor RZ-350 yet but my 010 in a EPS-300C gearbox works nicely.
In either case, you could use your existing gearbox and mounting scheme.
Old 08-16-2003, 06:17 PM
carrid02
My Feedback: (102)
Default 350!
If I want to put one of those Razor 350 motors on my Tribute and had a CC 20P ESC.... what battery/prop/charger would I need to get to make it perform?
Craig Rideout
Old 08-17-2003, 09:26 PM
dadzilla-5
Default two questions if you please...
Hi I just found this thread and I wonder if the razor 400 is actually speed 400 size? Also, what is the shaft size? Thanks!
Old 08-17-2003, 10:18 PM
PlaneInsane
The Razor 300,350, and 400 are all the same size. The 300 draws the most current, the 400 the least amount.
Shaft size is 2mm on all of them
