Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
prop shaft
Old 03-06-2011, 09:58 AM
flyntruk
Default prop shaft
Any suggestions for reveseing the prop shaft ? I want to do this on a Hacker motor so it will mount to the factory mount on a Park Zone P-47 motor mount . Is it even possible ? thanks
Old 03-06-2011, 11:21 AM
exeter_acres
exeter_acres's Avatar
Default RE: prop shaft
Hacker has reverse mount adapters available so you don't need to move the shaft. Allows for mounting on the front of the fire wall vs behind the fire wall...
otherwise.. loosen the set screw(s), remove the C clip, and then carefully press the shaft through.. probably has some thread locker on it.
I have a vise with a hole in it that I use.. another trick is to use a drill press with no drill bit and carefully press the shaft through........
Old 07-25-2011, 09:59 AM
thrushloader
Where can I buy 4mm prop shaft for 480 exceed rc motor?
Old 08-07-2011, 07:58 AM
Dr Kiwi
Try here: http://www.headsuprc.com/servlet/Categories
Old 08-07-2011, 07:02 PM
thrushloader
Thanks Dr. Kiwi, I think I have found it. Like always it's on backorder.  Mike
