2mm pinion for razor motor
Any one have any idea where I can purchase pinion gears for my razor 400? I just pulled my pinion from my gws 300 motor and the pinion is way to loose to fit on the razor.
My Feedback: (16)
Just JB weld it on. I took mine off my GWS 300 and put it on my Razor 300. I don't think the 400 has a different shaft size. If it's the same, it will be loose but not wobbly. It just doesn't have the splines to hold it in place.
If you search here I seem to remember people using Green Loctite. I had JB Weld laying around and it's held great for many flights.
Some people say to use CA and to make sure you clean and rough up the shaft a bit. CA did not work for me.
PS Just make sure you get it lined up before the glue sets
