wattage 370 gearbox change????
IN
I just bought my first electric and it is the Wattage Livewire, I have heard that the gearbox has problems stripping the gears but can be replaced with the GWS gearbox, but which one?
thanks
Steve Maxwell
thanks
Steve Maxwell
Hi Steve,
The stock Wattage Live Wire uses a Speed 300 motor geared at 4.78:1 with a 10x4.5 prop.
The equivalent GWS gearbox would be the EPS-300C (BS) 4.43:1 sold at AeroMicro.
GWS also makes a 10x4.7 prop that will fit right on the EPS-300C drive shaft.
Good luck!
Good luck!
