Hacker A60 7S V2
MI
Hacker A60 7S V2
Does anyone know if this motor can be converted to a front mount instead of rear mount? It came with "extra" parts with no description as to their use. Thanks.
MI
RE: Hacker A60 7S V2
I sent an email to tech support at Aero Models and here is their response:
Bob,
It is not possible to convert it without modification. The extra clips are just spares that are used in some of the other A60 motors.
If you need a conventional mount A60 S motor, the A60-22S V2 28 Pole would be the equivalent motor in the other mounting orientation.
So, there is the answer.
Bob,
