Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Running two ESC's and 2 motors?
Old 03-25-2012, 08:56 AM
wsmalley
Default Running two ESC's and 2 motors?
Is there any magic to hooking two ESC's/motors to your receiver throttle channel( for a twin EDF)? In other words will a simple 'Y' connector work, or would you need a reversing 'Y'? Bill
Old 03-25-2012, 09:43 AM
pilotpete2
pilotpete2's Avatar
Default RE: Running two ESC's and 2 motors?
Just use a standard Y harness, or a second channels on the receiver if you have an open channel and the ability to mix the throttle channel to the spare channel.
Using a reversing Y harness would result in one motor running full throttle with the throttle closed. A serious case of asymmetrical thrust
Pete
Old 03-25-2012, 10:25 AM
MajorTomski
MajorTomski's Avatar
If you are using the BEC function of the ESC, then some folks have pulled the red wire out of the plugh on the second ESC so that the reciever is not seeing two different voltages.
Old 03-25-2012, 11:16 AM
wsmalley
Probably sounded like a stupid question, but let me explain what happened! I had just received a second 100A ESC; however, it was a newer version of the same 'Sentilon' ESC. I had a programming card for the older version. Hooked the units up with a simple 'Y' and proceeded to run the motors up, each on 5S. Everything seemed to be o.k.! Then, I tried again and the newer motor started running in reverse, the older wouldn't run. Disconnected everything and tried to run the older ESC separate, Nada, nothing......... hooked up the programming card, no lights, nothing! Finally, after scratching my head and trying every combination, I checked the voltage on the Rx battery: 4.6V. Hhmmmm. Put it on the charger. It all works again. Apparently, that 4.6V can cause all sorts of wierd stuff. I just ran one motor on 10s and it spun the plane around in circles!
