If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Feb 2002
    Monterey, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Running two ESC's and 2 motors?
    Is there any magic to hooking two ESC's/motors to your receiver throttle channel( for a twin EDF)? In other words will a simple 'Y' connector work, or would you need a reversing 'Y'? Bill
    If I die, and I have the most toys, what do I win?
  2. #2
    pilotpete2's Avatar
    Join Date
    Oct 2002
    Lyndonville, VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Running two ESC's and 2 motors?
    Just use a standard Y harness, or a second channels on the receiver if you have an open channel and the ability to mix the throttle channel to the spare channel.
    Using a reversing Y harness would result in one motor running full throttle with the throttle closed. A serious case of asymmetrical thrust
    Pete
    \"If the woman don\'\'\'\'\'\'\'\'t find you handsome, they should at least find you handy\"
    [Red Green]
  3. #3
    MajorTomski's Avatar
    Join Date
    Apr 2003
    Oklahoma City, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you are using the BEC function of the ESC, then some folks have pulled the red wire out of the plugh on the second ESC so that the reciever is not seeing two different voltages.
    Spitfire Brotherhood #6
    Kadet LT 40 Brotherhood #98
    Ryan Aircraft (ST-A) Brotherhood #33
  4. #4
    Join Date
    Feb 2002
    Monterey, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Probably sounded like a stupid question, but let me explain what happened! I had just received a second 100A ESC; however, it was a newer version of the same 'Sentilon' ESC. I had a programming card for the older version. Hooked the units up with a simple 'Y' and proceeded to run the motors up, each on 5S. Everything seemed to be o.k.! Then, I tried again and the newer motor started running in reverse, the older wouldn't run. Disconnected everything and tried to run the older ESC separate, Nada, nothing......... hooked up the programming card, no lights, nothing! Finally, after scratching my head and trying every combination, I checked the voltage on the Rx battery: 4.6V. Hhmmmm. Put it on the charger. It all works again. Apparently, that 4.6V can cause all sorts of wierd stuff. I just ran one motor on 10s and it spun the plane around in circles!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
