Strange launching?
Strange launching?
Hi, i have a Losi XXL that i have just converted to Electric.
Spec is:
CC 2200KV motor
CC mamba monster ESC
6s Turnigy Lipo
Duderacing single speed conversion
24T pinion
63T spur
Futaba T3PK controller
As i slowly pull the trigger it will move away as it should but then it increasesacceleration(enough to bounce the front of the car) for a split second. Ever since the first start (without touching castle link) it has done this. Its the same in reverse. After the peak it is fine. It seems to carry on with the power curve as it should.
I have changed the throttle curve all the way down, punch control to 20%, start power to low. It doesnt stop itjerkingforward. No matter how slow or fast i pull the trigger it will still do this.
It also does it with no pinion/spur fitted so cant be the gearing/transmission.
Confused.
Dan
Spec is:
CC 2200KV motor
6s Turnigy Lipo
24T pinion
63T spur
Confused.
Dan
RE: Strange launching?
Hi Dan -
Did you intend to post your question here in the Electric Airplane forum? While you are welcome here, you will probably get more and better answers over in the Cars forum:
http://www.rcuniverse.com/forum/forumid_225/tt.htm
- Jeff
- Jeff
Nope.
The kind guys in the car section helped me. Couldnt figure out how to delete this thread, so was hoping it would just get ignored. haha
Thank you for the warm welcome though.
