If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    wooden electric props?
    I have acquired some wooden props that are lighter than the plastic ones. Is there any reason not to use them on electric motors?
    Would there be any difference if replacing with identical specs? How about max rpm? (of the wooden prop itself) They are cheap turnigy lightweight props , but I think they are really for engines.
    and airplanes were in
  2. #2
    Join Date
    Jun 2002
    high deserts, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: wooden electric props?
    they would get less stress with an E motor then the IC engine. only problem I had on one motor was tht prop adapter was to short to have a wood prop and a spinner.
    Buzz.
  3. #3
    Join Date
    Jul 2002
    St. Charles, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    First off, props don't care what the power source is that turns them. The hitch is that most e-props are under cambered to take advantage of the torque of motors, so e-specific props will perform differently than IC props of the same numbers. Best way to check is by using your whatt meter to check amp draw and a tact to check rpm.
    Walt
    WT in Illinois
  4. #4
    aeajr's Avatar
    Join Date
    Jan 2003
    Long Island, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Should work fine. Usually the wood are heavier, that is why electrics are usually plastic or carbon.
    Long Island Silent Flyers
    www.lisf.org
    Eastern Soaring League
    www.flyesl.com
  5. #5
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just got my first one balanced and mounted up. It sounds good and will try in a few days. Correction, these are intended for electric and the couple I've weighed have been lighter than a similar plastic prop. One had the hole way off center, one was ok. http://www.hobbyking.com/hobbyking/s...idCategory=299
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
