NEO 25 890kv set up for 3D flying
I have a 42inch extra that i want to set up for 3D flight and was wondering if the motor i have will be enough and if so does anyone know what size speed control would be ideal for it as well as prop an bat?? the speed control rang that is recommended is a 40amp to 60 amp.
Anything will help!
Anything will help!
TN
RE: NEO 25 890kv set up for 3D flying
Diameter: 42m (1.65in)
Length: 40mm (1.57in)
Weight: 149g (5.3oz)
Shaft Diameter: 5mm
KV(RPM/V): 890
Max Watt: 448
No load current: 1.2
Max Current: 55A
No. Of cells: 3-5S Li-Poly
Props: 11x8 to 14x7
Shaft Diameter: 5mm
KV(RPM/V): 890
Max Watt: 448
Max Current: 55A
Props: 11x8 to 14x7
