HiMax motor mount screw size?
MI
RE: HiMax motor mount screw size?
Pulled this info from the MPI Himax web site for your 3510 motor. As said above make sure the screws you use are not too long.
Specifications:
Weight: 89g, (3.1oz), Motor only
Max Power: 250W, (This is dependent on several factors)
Max RPM: 20,000 RPM
Diameter: 35.2mm, (1.39”)
Length: mm, 32.2mm(1.27”)
Shaft Diameter: 4.0mm (.1575”)
Mount Screw Thread: 4-40, max depth 5mm, on 25mm, (1.0”) circle
Maximum Case Temperature: 65
o
C, (149
o
F)
Specifications:
Max RPM: 20,000 RPM
o
C, (149
o
F)
