dualasky motor
dualasky motor
hi all. i have a dualsky 2208 kv 1370 i bought it about 6years ago and never ran it. i need to get the shaft pushed through the motor so i got some shaft for the prop. it came this way, with the shaft pushed as far back from the front,its almost flush with the front motor molding.my problem is there are no set screws/shaft collar locks. do you think it might need to be pressed forward? thank you.
TN
RE: dualasky motor
Almost certainly it will be an interference fit, and you'll need to press it through in a vise...use a suitably sized hex-socket as a spacer.
