E wooden props will theybend motor shafts
My Feedback: (7)
I have a question on using a electric wooden prop or a glow engine zinger wooden prop on a 3mm or 4mm Electric motor shaft in the 450 to 480 class motors
[ without a prop saver ] , will these types of wooden propellers bend the shafts on the motors on a simple nose over as compared to a E Gws direct drive prop or E master air screw even the E APC , I was told they will snap instead of bending the shaft, how ever ,they look pretty hard to me as compared to a more flexed E nylon , anyone have any experience with these wooden props ?
FL
RE: E wooden props will theybend motor shafts
I ran em on my .25 Cub, and both my Hangar 9 Camel and NP DR1. I've boinked more then my fair share of props on these and I've never bent a shaft.
But not to say it can't happen. Wood does not flex like plastic/nylon. they usually just break when they hit.
A tip too, wood compresses, so check your prop for tightness before every flight.
My Feedback: (7)
ORIGINAL: Glacier Girl
thanks for the information on wooden props, I emailed you a message ,please check
I fail to understand the design logic of using a pin size shaft (3mm or so) when a 10" diameter prop will be put on the end of the shaft. Looks like a recipe for unnecessary shaft replacement.
Bill
Bill
My Feedback: (7)
ORIGINAL: BillS
I fail to understand the design logic of using a pin size shaft (3mm or so) when a 10'' diameter prop will be put on the end of the shaft. Looks like a recipe for unnecessary shaft replacement.
Bill
Bill
My Feedback: (7)
ORIGINAL: suzonka
