Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Wattage ultimate biplane brushless conversion
Reply
Old 03-12-2014, 07:38 PM
Mark@ny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wattage ultimate biplane brushless conversion
I need some help selecting a brushless motor ,esc, prop and lipos for a wattage ultimate bipe. Looking for some low budget options. Looks like a nice little plane that's built up covered and not made out foam. I have a hackerA20-20L and himaxx 2815-4000 available.I am not opposed to using a gearbox with the himaxx.
Mark@ny is offline
Old 03-13-2014, 07:37 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane is around 32oz so the Himaxx is well suited for good aerobatic performance at close to 150W/lb...., since it is rated for 275W (86g @ 3W/g is close enough) .......(the 57g Hacker can't manage that). Determine the correct prop size then gear accordingly... at around 4:1 gearing you'd have a Kv of ~1000Kv which should allow 10"-12" props, while keeping the amp draw at ~ 25A.
Dr Kiwi is offline
Old 03-13-2014, 08:10 AM
Mark@ny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info, I could use a little more info. What company gearbox? What amp ESC ? The plane was originally designed for a 7x4 prop. 10" I think is the max that could fit. I have a 25 amp brushless speed controller to use if possible. I am not looking for 3-D performance just good spirited flight.
Mark@ny is offline
Old 03-13-2014, 09:46 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why don't we go with your 25A ESC and an 8x4 APC E: I'm guessing your motor would fit a GWS 400-style gearbox. One can get several different ratios. http://www.allerc.com/hyperion-alumi...v2-p-1579.html
~260W is still ~130W/lb.. should be plenty.
Motor: HiMaxx HA2815-4000; 4317rpm/V; 4.2A no-load; 0.016 Ohms.
Battery: Thunder Power TP4400 (G4 ProPower 45C) (45C); 3 cells; 4400mAh @ 3.7V; 0.002 Ohms/cell.
Speed Control: Castle Creations Phoenix 25; 0.0065 Ohms; High rate.
Drive System: Geared; 8x4 (Pconst=1.47; Tconst=1) geared 3.6:1 (Eff=80%).
Airframe: Anything you want.
Motor Amps = 24.7
Motor Volts = 10.8
Input (W) = 266.4
Motor RPM = 44502
Prop RPM = 12362
Thrust (oz) = 31.5
PSpd (mph) = 46.8
Dr Kiwi is offline
Old 03-13-2014, 02:24 PM
Mark@ny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is a 4400 mah pack necessary ? I have a 2100 mah pack from another plane don't remember the C rating. I would like to know a possible outrunner recommendation as well. Thanks for the help.
Mark@ny is offline
Old 03-13-2014, 03:00 PM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh heck... sorry... that battery was just in MotoCalc and I didn't correct for what you actually need! ANY battery which can deliver ~25A will do (1000mAh/30C... 2000mAh/15C... etc... would do)....... mAh capacity will simply determine flight time.
Dr Kiwi is offline
Old 03-14-2014, 12:56 PM
Mark@ny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think a outrunner might be an easier choice since I can't locate a gear box that will fit a 2815-4000 due to its 28mm outside diameter.
Mark@ny is offline
Old 03-14-2014, 06:17 PM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This should work for a 28mm OD motor. http://www.allerc.com/hyperion-alumi...v2-p-1579.html
Dr Kiwi is offline
Old 03-17-2014, 04:44 PM
Mark@ny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The gearbox from allerc.com I don't think will work. Besides the o.d. of the can being 28mm not 20mm,the shaft size is much larger than the pinion available I am willing to save the himax for something else. But I would like a recommendation for an outrunner but possibly still using the 25amp speed controller I currently have. Maybe something from hobbyking or BPhobbies.
I tried to contact himax since they offer the 2815-4000 witha gearbox to see if it was available separately but they did not respond.
Mark@ny is offline
Old 03-18-2014, 06:55 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think that a 28mm OD motor would fit, but, yes, you'd need 3.2mm pinions.
Here is an Exceed 2220 motor (28mm OD) in a similar gearbox.
Name:	Exceed Optima 2220-2700 640.1.JPG
Dr Kiwi is offline
Old 03-18-2014, 10:25 AM
Mark@ny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The pinion shaft is 4mm. Do I still use a 3.2mm pinion and press it on or is there other mods to be made. Thanks for the help.
Mark@ny is offline
Old 03-18-2014, 12:25 PM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My mistake.. I looked up Himaxx 2815 and their chart said 3.2mm for the three lower Kv versions... but I missed the fact that the -4000 is 4mm!! http://www.rcdude.com/servlet/the-49...nrunner/Detail
I don't even know whether 4mm pinions are available.
Dr Kiwi is offline
Old 03-26-2014, 08:12 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I find the electrifly calculators work well to help define a motor or specs to use to go shopping
http://www.electrifly.com/powersyste...tem-index.html
I have had very good experience with Rimfire motors.
aeajr is offline
Old 03-26-2014, 11:42 AM
Mark@ny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the response. Since writing last I was given a HK 2040 4800kv inrunner I have an e flight 6.6 to 1 gearbox . Is this a usable combo with a 25amp speed controller ? What prop?
Mark@ny is offline
Old 03-26-2014, 11:54 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At a guess I'd say about 12x6 on 3s would draw ~20A.
I'd certainly start with no more than 10" with my Wattmeter in hand!
Dr Kiwi is offline
Reply
Display Modes
