Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
robarts retract binding
Reply
Old 04-20-2014, 07:58 PM
CISCOPANC12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Smile robarts retract binding
I am having problems getting the gear to retract. replaced with new actuator new pin and brass fitting plus new trunion. the actuator moves up approx 1/4 " and stops. are there any adjustments I should check. Could the problem be with the grove when in the gear down lock position. I did break the trunion during hard landing. AC IS THE TOP FLIGHT 86.5 SUPER MARINE SPITFIRE.
THANKS FRANK
CISCOPANC12 is offline
Old 04-21-2014, 01:52 PM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look very carefully to ensure the retract is mounted flat.
Remove it from its mount and see if it binds
BarracudaHockey is offline
Old 04-22-2014, 08:25 AM
CISCOPANC12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for quick reply. upon removing the gear i found the trunion pin tight, and the pin/torx holding the bass cam roller was at the high point of the side frame. When I removed the trunion pin the actuator worked all the way, up and down.
Reply
Display Modes
