What SBEC does everyone like to use?
I want to standardize to one SBEC that will perform well with all my planes. I was looking at using this SBEC by Turnigy
http://www.hobbyking.com/hobbyking/s...arehouse_.html
I run 2 to 8 standard servos, depending on which plane.
Thanks for your input
Depending on the servo size, that may be enough! If not, you can use two, and split the servos between them.
(red servo wires are divided between, black wires are common. The servo signal (white or other non red or black color)
goes to the usual RX, along with the common.
