Need Help finding High Voltage BEC options. Quality preferred
Hello all, I am building a flying wing using 4 digital servos. It is a small motor which can easily be run by my 35 amp Commander ESC. It is new in box however it is 8 years old so it is the old version, it might not matter because my airframe requires 7.4 volts per servo. Can someone direct me towards a 35-amp ESC with a 7.4V BEC? I realize this might be asking a lot however I am only using four servos and am willing and able to use an external BEC. The airplane has a camera in a bubble canopy and looks really nice I have room for an external if required.
If someone could explain my options that would help a lot my airframe will be done soon and it would be nice to have my electronics setup.
Thanks so much in advance will post link to build thread once I get going further
Ar
Ar
My Feedback: (9)
I am far from an electronics expert. But maybe me jumping in will get you some more help. I would go at this issue with a lipo that has two leads using one lead to run the RX and the second to run the ESC. A 2 cell will you give you the 7.4V you ask for. A LiFe can also be had with 2 leads but is only 6.6V. I think this type of batter would simplify your set up a little. I have used one like I posting below with great success. It does not charge through a Dean's so you may need a Smart Fly to charge it if you don't have one.
Hope this help, david
http://www3.towerhobbies.com/cgi-bin...?&I=LXEBHR&P=7
Very interesting, I purchased a Castle Creations 10 amp BEC and a usb programmer. Now i can tune any future CC ESC's and I can set it for 7V. This should allow my esc to not need ventilation.
Yes, the scorpion esc and CC BEC should pair up with out problem.
I will post a link here to the build thread once I finish the Airframe. I'm interested as well as these servos are very light and have 100 and 70oz respectively(4 servo elevon) thanks
