Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Motor wires thinner than ESC wires, please HELP
Reply
Old 03-24-2017, 09:34 AM
shd3920
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Motor wires thinner than ESC wires, please HELP
I have a 10gram electric motor that has very thin wires, thinner than the 12amp ESC wires (by at least double) The ESC is 20awg. Can the 20awg ESC wires be soldered directly to the thinner motor wires without any issues?
shd3920 is offline
Old 03-24-2017, 12:38 PM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, no problem.
The wires on the esc are probably heavier than needed and may just have thicker insulation. The wires on the motor in most cases, are just the actual motor winding wire covered with heat shrink. The 20A esc is probably a bit overkill for that size motor, but that's not a problem. I always use a larger esc than necessary, and in 13 years of running brushless motors, I've never had an esc fail.
Pete
pilotpete2 is offline
Old 03-24-2017, 03:29 PM
shd3920
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the quick response. The ESC is 12amps. The ESC wire awg is 20
shd3920 is offline
Old 03-27-2017, 08:56 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your ESC wires were smaller than your motor wires, then you should be suspicious that the specs are mismatched. Fact is you could solder the 12A motor leads to a 75A ESC, basically if the ESC is bigger than the motor needs and the wires are bigger.. then you're laughing and the ESC certainly won't be under any stress. It might weigh more than it has to is about the biggest drawback.
ESC's don't force current upon the motor, they supply what it draws based on the rpm and load. So a big ESC doesn't do anything to a small motor other than perhaps offering less internal resistance and a couple more rpm.
MJD is offline
Old 06-16-2017, 02:54 AM
TTF-Nicholas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, it's no problem to solder them together, as long as the MAX CONTINUOUS CURRENT of the motor is NO HIGHER than 12amps.
It doesn't matter whether the motor wire is thin or thick.
TTF-Nicholas is offline
Old 06-17-2017, 08:25 AM
ron_van_sommeren
ron_van_sommeren's Avatar
Location: Nijmegen/the NetherlandsNetherlands, NETHERLANDS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Watery analogy: your 3/8" kitchen watertap pipe is connected to a several inch mains water pipe, no problem.
Pressure and pipe determines maximum current, tap determines actual current.
Controller does not forcefeed motor with electrons.
Voltage, Kv motorparameter and prop determine maximum current, controller determines actual current.
actualPrettig weekend Ron
ron_van_sommeren is offline
Contact Us Archive Advertising Cookie Policy
