Push button throttle
Hi all,
new to the forum so I apologise if this is in the wrong place.
strange one, basically I need a way to adjust the speed of a brushless motor with a push button (the more the button is pushed in the faster the motor spins). This will be a wired connection so no transmitter/receiver. Using a servo tester this is easy to adjust the motors speed however I would like it to be a linear movement instead of rotary. Does anyone know of way to do this?
