Need 35-40 amp brushless ESC + BEC recommendation
I'm upgrading my fleet of brushed Speed 400-based combat foamies to use a modern E-Flight Six Series 2000 Kv brushless motor.
Can I get some brushless ESC + BEC recommendations in the 35-40 amp range for the following use case:
- the motor and the ESC will be embedded in EPP foam with very little ventilation, so I need something that will stay cool
- I will *not* be pushing this motor hard or running it fast; I plan to use a folding prop on an as-needed basis to stay aloft and penetrate the wind
- I need to program a soft start as well as a brake setting for the folding prop
- I will probably only run at 7.2 volts, but I'd like the option to try out an 11.1 volt battery as well
Sorry for the jumbo image - not intended.
The offerings from Graupner USA (while expensive) look promising:
https://www.graupnerusa.com/Brushles...Telemetry.html
