Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
How does a brushless motor work?
Reply
Old 09-04-2010, 08:33 PM
  #126
Dongskie
Dongskie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How does a brushless motor work?
Hi Guys,
Thanks for the explanation on BLmotors, I too was at a loss at the beginning..
One question though,I have a non-sensored Bl ESC anda friend gave me his sensored BLMotor because he fried his BLESC,can I use the sensored BLmotor with my nonsensored ESC? I am afraid to try coz I mught fry my esc in turn
Thanks guys!
Dongskie is offline
Old 09-05-2010, 01:23 PM
  #127
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can use a sensored brushless motor with a normal sensorless ESC, but you can't do it the other way around. Just leave the wires from the Hall effect sensors on the motor unconnected.
Pete
pilotpete2 is online now
Old 09-12-2010, 06:56 AM
  #128
Mr ace
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would like to be able to choose the right motor for my plane. Is their anywere to find software that I can simulate the motors, props, weight of plane. I woud like to know some of this info before I buy? Any help??
Mr ace is offline
Old 10-31-2010, 10:44 PM
  #129
drive2survive
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
speaking of motors, maybe someone here can figure this problem out>>>>>>>went out flying today and hooked the the bat to the ESC, it smoked a bit and the motor didnt go, so took it back to the shop and tried another ESC, the new ESC got warm and the motor burped but didnt go..........so hooked up direct power +- to the BL motor and nothing happened, know anything about this??
drive2survive is offline
Old 12-01-2010, 08:47 PM
  #130
Stephen56
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fantastic info on brushless motors. Ron's post's clarified things a lot. I knew there had to be some differences to industrial AC motors, since those have a fixed rpm. The tech jargon would be a bit much for anyone without an electrical or engineering background. I'm glad an EE was in the discussion. If you want to fry your brain, investigate electrical space propulsion. Just bought my first brushless off road truck instead of a college grad. ring. Awesome!! UAHuntsville from the rocket city. Charge on!
Stephen56 is offline
Old 02-02-2011, 05:29 PM
  #131
jerrydearmond@rocketmail.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to find that out, This was a mystery Thanks-
jerrydearmond@rocketmail.com is offline
Old 04-16-2011, 08:36 AM
  #132
band1086
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An interesting reply post from a guy in Sweden:
Quote
this switched DC changes from full + to full - instantly.
If it had said it is shifting between full + and zero instantly. It would have been DC.
But then you change polarity it's AC no matter the form of the curve! AC when you pass zero. DC when you don't reverse the electron flow. You can go to zero but not reverse the flow!
So if you only push OR drag the magnets you use DC. But if you push AND drag you use AC!
So you can use both type of waves. For DC minimum is zero and for AC it is as much negative as positive. Depend how much force you wanna have your electrons to make!
Here you can see DC on wikipedia and AC on wikipedia.
band1086 is offline
Old 05-24-2011, 11:46 AM
  #133
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This should resolve all questions.
www.microchip.com/stellent/idcplg
Explains in detail how the BLDC motor works. Note it says DC, not AC. It is 3 phase, but DC powered. The voltage flips from + to - in relation to ground. The only part that has me a bit puzzled, 3 Phase requires 4 wires, whether it is AC or DC, the 3 phases + Neutral for AC, or ground for DC. The ESC has only 3 wires, so where is the ground?
And yes you can push/pull with DC, pull with Positive and push with Negative. In relation to ground or zero (0). Thats how PC's work, Check out the power supplies in a computer, you have +5 v and - 5 v in relation to ground.
The PDF has all the details on the motor and controller.
acdii is offline
Old 05-24-2011, 01:33 PM
  #134
RAULOR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A Brushless of this type of motors for Hobbies works with a DC Input, however, the ESC does a similar function as a typical DC-AC Inverter, it creates a 3 phase AC output from a DC input. Normally a sensorless type uses only two phase for the commutation, while the third is used for positioning sensing.
There is not a "steady" ground wire here, since they are all going through zero on a sequencing bases.
The ESC besides the DC-AC conversion it also pulses and synch the waves in a timely fashion through an Oscillator and according to accel of the V.R. (Variable Resistor) and C.L.(Current Limit) set .
RAULOR is offline
Old 05-24-2011, 03:46 PM
  #135
sky9flyer
sky9flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it operates on a positive ground, it will only have three wires.
sky9flyer is offline
Old 06-27-2011, 01:44 PM
  #136
wtjonessss
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How do elec motores make sounds
wtjonessss is offline
Old 06-27-2011, 01:52 PM
  #137
wtjonessss
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How do elec motors make sounds and music ? I have a JR and the TX beeps and the elec motor beeps also and at the same time as the TX beeps !
This has been bugging me for a long time "
How do they do it ?
wtjones8@yahoo.com
Thanks much, Wally
Old 11-06-2011, 02:12 PM
  #138
larrytoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will a single ESC control two non interconnected outrunners? Just a beginner (to outrunners) here, but I doubt it.As I see it, it would be virtually impossible for both motors to see the same prop load so current would not be even between them and the phase of the "sensing" wave form from each would differ. Since this would be combined, I would think at best that the ESCwould be VERY cornfuzzeled!
Larry
Elsewhere on this site I posted a cry for help with connections and "programming" an ESC.
larrytoo is offline
Old 11-06-2011, 02:36 PM
  #139
larrytoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How does one measure the current and power use of an outrunner?  Can one just meter the battery wire to the ESC (yes, there would be some esc load and some xcvr/servo load)?
How is it that outrunner speeds are given in rpm/volt (unloaded)?  Does the ESC sense the input voltage and use that to limit the motor speed?
I'm trying to understand/program/use a Gunther BG (1400Kuv, 25A, 240W) outrunner with a Dymond Futur(E) ESC but have no instructions (and NO help from the supplier in Homestead Fla (posting his replies to my questions might constitute a FLAME!)).  Stick programming of timing, throttle, brake, autocutoff, cutoff, soft start is claimed, but how  do I do it?????
Can anyone be of assistance?
larrytoo is offline
Old 11-06-2011, 02:42 PM
  #140
larrytoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure, the v-tail mixer could be used to trim the two motors to nul out any residual (drag inducing) rudder angle when not turning. May also be a lower drag solution when making wide turns or small course corrections. (I once, in a past life, conned a cruiser with one shaft locked, used differential RPM's on the other three shafts to aid in steering).
Larry
larrytoo is offline
Old 02-01-2012, 10:40 PM
  #141
scott88-RCU
scott88-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm glad to see that this post is still up! Haha it's been a while...
scott88-RCU is offline
Old 02-18-2012, 12:52 AM
  #142
chuckk2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Motors may be Y or Delta.
chuckk2 is offline
Old 04-15-2012, 12:54 PM
  #143
tootalltechie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was thinking of using a brushless DC motor as a starter motor on a G26 zenoah instead of the pull start. Any idea how and what size of motor I would use. Also if I connect straight to the shaft, any harm in letting it run no current when motor is running?
tootalltechie is offline
Old 01-04-2013, 07:32 AM
  #144
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you would like to look at all that surrounds the motor, this is a good resource.  this on-line book talks about batteries, ESC and the other elements that surround the motor.
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
aeajr is offline
Old 05-19-2014, 11:26 PM
  #145
peterwilson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I came accross this website to read more info on this great product: http://www.directindustry.com/indust...tor-61102.html
peterwilson is offline
Old 08-29-2014, 08:07 AM
  #146
wrdotson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question What about powering multiple brushless motors together?
If the ESC needs to sense the state of the motor's rotation to operate properly, doesn't it follow that trying to run multiple motors with one ESC could be problematic? I have an RC blimp (homebrew) that I built with a friend about 40 years ago, and the 4 motors, 6v hobby type, are all wired in parallel to a traditional pulse width speed control. If I update these motors to modern brushless, what do I need to know? The main reason for the upgrade would be to save weight, which is critical, so multiple ESCs would probably not be an option. Any thoughts?
wrdotson is offline
Old 06-02-2015, 12:12 AM
  #147
Ashraine William
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what motor you use?
is it not working since you bought ?
Ashraine William is offline
Old 01-13-2016, 07:54 AM
  #148
ron_van_sommeren
ron_van_sommeren's Avatar
Location: Nijmegen/the NetherlandsNetherlands, NETHERLANDS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vriendelijke groeten Ron
196,261
ron_van_sommeren is offline
Old 01-13-2016, 02:21 PM
  #149
ron_van_sommeren
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Ron v. Sommeren View Post
... CD-rom outrunner motor simulation
http://www.meinpapi.de/dieter/JAMO_0-33Wi10Abig.gif
LRK outrunner simulation, different colours for different magnetic field strength:
http://www.mfly.de/animation_b.gif
The outrunner simulations links are dead, but I found them and one extra.
196,269
ID:	2141213   Click image for larger version
ID:	2141214   Click image for larger version
