***counter rotating propellers on a C-130?
PA
Does the below Article refer to this C-130 which I building, please go to link below to see the plane.
http://eapg.org/Reference/C-130/Instructions.htm
Article:
On a two motor airplane that one motor turns the propeller clockwise and the other motor turns the propeller counter clockwise. Because the motors run in different directions (and the propellers turn one clockwise and the other counterclockwise) you eliminate the need for right thrust.
-on a four motor airplane you will have one wing with two motors turning clockwise and one wing with two motors turning counterclockwise.
If the design of the plane is not originally for counterrotating motors (and propellers) you will have to eliminate the rightthrust that is normally build in the way the motors are mounted.
Bob
Article:
Bob
My Feedback: (21)
RE: ***counter rotating propellers on a C-130?
If you're not an experienced builder, I would recommend against making major modifications to any design like that. The full-scale C130 was designed with all engines turning the same direction, and presumably the model was as well. I know of only one full-scale airplane with counter-rotating props, and that's the Lockheed P-38 WWII fighter. Even then, the French or the Itailians (can't remember which) had Lockheed produce a special version with both props spinning in the "conventional" direction.
Counter-rotating props also opens up a whole new can of worms. Mainly, it's in finding matching propellers. You need two reverse-pitch propellers that are mirror images of the conventional-pitch props, and finding them is no easy task.
Moderator
I agree with Matt, that unless you're a VERY experienced builder, I would not recommend that mod.
(ditto if you're not an experienced FLYER )
there are however several full scale production airplanes that use counter-rotating props...
the Beech Dutchess, the Russian "Bear" and the Cessna 337 for example. (well, the 337 gets in on a technicality )
http://yarchive.net/air/airliners/p_factor.html
