Capacitors on brushless motors?
CA
i am trying to decrease electric noise coming from my motors. they are brushless feigao motors, and am curious as to whetherit would make a difference if i were to cap them like i would a normal brushed motor? that would require 5 capacitors. will it work?
My Feedback: (21)
RE: Capacitors on brushless motors?
My question is, how do you know it's noise from the motors?
Brushless motors have no brushes with which to generate noise. Everything's hard wired.
ON, CANADA
Wouldn't really work. The RF noise comes from the arcing of the brushes. No brushes, no noise. Try separating the antenna, speed controller, batt. as far from one another as possible, although it's hard to do in these little planes.
ND
ORIGINAL: Spaceclam
it's seemingly the only real source for noise.
NY
lol I was searching RC universe to see if the capacitors on brushless esc effect performance and found this funny thread.
Do people even know how brushless motors work? A capacitor stores electric charge to flatten out alternating waves. DON'T put them on a brushless motor.
Brushhless noise problems are from parts layout and loose connections.
Including the the antenna wire being broken anywhere in the length of it. A GENTILE pull on the end and holding the receiver JUST ENOUGH, will show if it is broken with the motor on low speed.
2 people are needed for safety reasons !!!!!!!!!!!
Rich
Rich
ORIGINAL: Matthew007
Vriendelijke groeten Ron van Sommeren
• int. electric fly-in, Nijmegen, the Netherlands
• brushless motor building tips & tricks
• diy brushless motor discussion group
• Drive Calculator download & discussion group
The correct answer issssssssss.
No capacitors across any brushless motor.. unless.. you REALLY know how to calculate the capacitive reactance of the capacitor at all RPM's.
Very few engineers know how to do it. Then they still need to know how much power the capacitor can take. Even fewer know that.
NO capacitors. Period.
Rich
WI
My AXI 4120 supposedly has caps on it according to the instructions. There is an additional lead inside the insulation of each of the leadouts which the instructions say are capacitors.
Mike
Mike
Could be.
They would be to prevent excessive spikes right at the windings. Right place.
Stilllllllllll. We do not want to just start putting them in. Bad things can and WILL happen if we get it wrong.
Rich
WI
Mike
If you are having range issues causing glitching as the reason for wanting to reduce electrical noise, try a different motor speed controller. I just had a new one really mess up my systems range. Changed controller, problem solved.
John C
John C
WI
Or just get a 2.4GHz spread spectrum system and kiss your glitches goodbye.
Mike
