Align Motors
AR
RE: Align Motors
Here is an EBay site where we bought an Align motor. The site had all the specs for that motor. Maybe you can find out about other motors and specs there.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
Good luck.
Good luck.
AR
RE: Align Motors
I'm back. Here's their site, just click below:
[link=http://www.align.com.tw/shop/product_info.php?cPath=22_67&products_id=745]Align[/link]
Hope it helps
Hope it helps
RE: Align Motors
One bit of warning on the Align motors make sure the mounting screws you use are no longer than 5mm, clearance is very tight.
I have a 400 2500kv and a 2800 kv and they draw about 28 to 30 amps with a 6 x4 APC pusher prop and a Kokam 15c 2000 3 cell lipo.
Wood Duck
Wood Duck
My Feedback: (31)
NJ
RE: Align Motors
Quack, quack, thanks Mr. Duck. I'll be using mine as a pusher also, but I'll use a clamshell mount and not the screws through the front. Thanks for the tip though; quack, quack. Do you know the watts and thrust of your set up? I'm looking at either the 400SF or LF. These are 2200kv motors and they're claiming a max of 200 watts at 25 amps. Quack, quack. Go to the wet forum and look under 1/2a planes and look for the X-Wing Interceptor I'm putting it in. Quack.
