Cool Running ESC
Cool Running ESC
I tried out the A-12 ($34.95 US) I ordered from Cool Running (COOLesc.com) and am most impressed. I put together a stick trainer for my grandson using a Little Screamer. The original ESC would not self start the motor and had poor low speed performance. The A-12 ESC started the motor with no trouble and I had excellent low speed control. Also, flight times increased and there was a noticeable reduction in motor temperature. I had the plane in the air for more than 1/2 hour and used about 50% of the battery's capacity. Prop is a 9x6, battery is TP 1320 2S, and AUW about 13 oz. The Watt's Up says this lash up is running 5A WOT.
RE: Cool Running ESC
To be honest, I would rate it equal to my CC controllers (4). CC has the edge on ease of use because of the PHX-Link, cool running has the edge on price. Performance wise I see very comparable results between Cool Running and CC. I have an older Jeti (1), E-Flite (2), Tsunami (1), and a Balsa Products (1) BL controllers. Cool Running and CC are definately on the top of my list.
wreck,
thanks for posting about these ESC`s although i went to there web site and they are sold out of the ones i need until august 26th so i will have to wait until then to get 1 . looks like it will be a good match for my AXI 2814 in my super sportster EP.
bassman
bassman
Thats good info guys thanks, i've ordered a 12 and 25 for test with the view to importing them in to Aussie, with freight and exchange rate there going to be about 60% of the price of CC esc's
