370 Brushed geared 1.8:1 PLEASE HELP ME
My electrajet motor is dead. It was a 370 geared 1.8:1. This was one of my favorite planes. Can someone please recomend a BRUSHED replacement for this set up. AND it was a pusher. Please help.
RE: 370 Brushed geared 1.8:1 PLEASE HELP ME
Hi,
I have used the GWS EPS-350 systems in three planes (before I went brushless ) and I was very satisfied with the performance, price and endurance of these machines. As far as I know, the power of the GWS 350 is the same as the 370. Their fastest gear setup seems to be 2,8:1, but maybe you can find a suitable propeller to get the pitchspeed up.
http://www.gwsus.com/english/product...em/eps350c.htm
Good luck!
Andreas
Good luck!
Andreas
Hi again,
Just came to my mind that if your gearbox is OK you don´t have to change the whole motor. I think that the GWS 350 is equal to the 370 in size also.
Andreas
Andreas
BTW, GWS sells a "PINION GEAR PULLER SET" http://www.gws.com.tw/english/product/other/gp.htm for trouble free removal of the gear on the motor.
TN
The GWS 350 is simply a hotter (higher Kv) "6v nominal" version of the "7.2v nominal" stock GWS 300. Both are "Mabuchi 370" motors, just as all GWS 400 motors are "Mabuchi 380" motors. Graupner 300's and 400's are Mabuchi motors too.
