Speed control prblem?????
CO
Hey gang,
I have a question that I need help on.
I have a mini Funtana witha 3c 1100 lipo pack.
Last summer I flew it a few times with no problem.
At the end of the season I bought a mini receiver to replace the full sized received that I was using. I just put it in my plane, now when I power the plane up the speed control beeps one time. after I move the throttle from high to low the prop jumps a little and the speed control starts double beeping and the motor does not turn. The rest of the surfaces work perfectly.
Can any one tell me what I might have messed up?
The speed control is a 25 amp e-flite.
Larry
Larry
AZ
RE: Speed control prblem?????
Have you tried to put the old receiver back in the plane and see if the plane acts the same? This will eliminate the ESC or not.
CO
I have not I will put the old receiver back into the plane to check that out, if that doesnt work I will try to re-program the speed control.
Larry
Larry
