Phoenix 45HV will not arm?
PA
I have a CC Phoenix 45HV which I have used on 6S and it fires up no problem. I tried to go to 12S but it will not arm. It will not arm on 3 4 or 5 s either. Any idea what could be going on? There is A bec attached and everything worked fine on 6S lipo.
UT
RE: Phoenix 45HV will not arm?
Some possible troubleshooting. That ESC requires at least 4 cells, so that may be why it won't arm with 3, but why it won't arm with 4 or 5 is beyond me. Possible reason it won't arm with 12 is that your UBEC cannot handle that much voltage and is not powering the Rx correctly. Arming is done through the Tx and Rx and that signal is sent through the signal wire to the ESC. Perhaps there is a communication problem between the Tx and Rx.
