Hacker 20-20L HELP!
My Feedback: (72)
MO
Hacker 20-20L HELP!
Ok, I just bought a Hacker A20-20L and the instructions are in German! All three power leads are black. How do I know which one is red, blue, and black? Also, I figured out how to bolt the one prop adapter to the front. How do you use the one that fits over the shaft? (it sticks out the back of the motor) As you can tell I'm new to electric but I've been flying gas forever.
RE: Hacker 20-20L HELP!
The wires do not matter on Brushless. There really is no positive, negative, if you hook it up and it turns the wrong way just switch any two wires.
I am guessing that the other prop. adapter is a regular collet type or something, the only way is to loosen the allen screw or e-clip holding the shaft in place, and simply pushing it through to the other side then resecure it.
I don't think he means the collet I suspect he is talking about the props you hold inplace with a black rubber thingy! whats it called a prop saver?
this is for a very light park flyer no?
Does the back you speak of look something like this?
http://www2.towerhobbies.com/cgi-bin...?&I=LXJEW0&P=7
you would need this part to wrap it round the prop and shaft which i just showed you
http://www2.towerhobbies.com/cgi-bin...?&I=LXJPH2&P=7
here is what it looks like on the front of the plane
its a small pic but im sure you can make it out.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJTK2&P=0
if this isnt it then I'm sorry about that I must have gotten confused a bit
sorry!
sorry!
