Jeti ESC question
Jeti ESC question
I picked up a Jeti 30amp esc and I'm getting conflicting answers to this question, can I run 4 servos without some sort of BEC. I'm running 3s lipos, two hs-55's and two hs56's
Thanks in advance
Thanks in advance
RE: Jeti ESC question
You didn`t say which controller... If it is for a brushed motor the answer is in fact YES. Read the .pdf-manuals for the controllers on this web-page, because this is the source: http://www.jetimodel.cz/eng/hlavnien.htm
In short: If it is a brushless Jes ESC the answer is also YES. If it is an brushless Adv ESC the answer is NO.
Your servoes are of the high consumption kind...
BC, CANADA
ORIGINAL: Dewane
Thanks in advance
Thanks in advance
Thanks guys, its the Jeti advance 30 plus and it will be running a brushless Axi.It says its Lipo ready so I hope the lvc is correct,I dont know how to check for that.
Looks like I'll be ordering a bec. Thanks
